Scangauge 2? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-24-2011, 03:26 PM Thread Starter
Quoted: 4 Post(s)
Scangauge 2?
What will it do for me? My truck is getting crappy MPG and I was thinking of buying one just to go over everything to make sure its in order. Can you change the speedo with it, FICM voltage, Injectors, fuel pressure? What else? Thanks
2008 F250 King Ranch 4x4
5' Flo-Pro, GearHeads Tune, Coolant Filter
Sold: 2005 F250 King Ranch 4x4
Toyo's, SCT, Blue Spring, EGR Delete ect
justinp95 is offline
post #2 of 4 Old 06-24-2011, 04:03 PM
Scangauge II is ONLY a monitoring solution and is NOT a programmer. You can program the X gauge feature to monitor any factory-supplied data. The Scangauge II will not monitor Fuel pressure, EGT or Low pressure oil system. I got one from Bullet Proof Diesel and it was preprogrammed with a lot of the X Gauges that are needed for the 6.0 for less than $200. There have been a lot more X Gauges developed than what they show you on the website. Some of the basics are FICM voltage, Main system voltage, EOT, ECT, IPR,ICP, Boost, MAP, EBP, ect........... A simple search will help you find all of them you should need and a few you don’t for the price I am very happy with mine. See the links below.
Products : Linear Logic - Home of the ScanGauge
Some Scangauge II Codes for "Xgauge"
HAM_RADIO_MAN is offline
post #3 of 4 Old 12-30-2011, 02:31 PM Thread Starter
Quoted: 4 Post(s)
So i bought one and forget about this thread... My MPG is showing up in any from 933 to 1200, whats the deal with this read out?/?
post #4 of 4 Old 12-30-2011, 02:37 PM
Quoted: 6 Post(s)
The MPG feature has to be programmed: Saving Fuel : Linear Logic : Home of the ScanGauge
Call the guys at Linear Logic I know they will be glad to help
a2elvis is offline
