Help identifying A/C hi pressure and Low pressure fittings for vacuuming system
This is the first time to do any a/c wok so bear with me. I had to replace the A/c hose. So im going to vacuum the system. There is 2 nipples on the same line and then another on the canister. Why is there 3? and which one is low and which is high?
![]() thanks |
LP side should be the larger tube, and HP the smaller. It doesn't matter which access port you use
If I had my truck here, I'd make sure I was right, but that's traditionally correct, as far as the LP and HP lines are concerned |
So from looking at mine there is not a LP acces port on the actual hose/line its in the cannister? Or do I have it backwards?
Yes, the LP (suction side) you will use the port on the canister, and the HP line is the line leaving the compressor and going to the condenser
thank you for your help
Anytime
