Oasis Report Please - Ford Powerstroke Diesel Forum
Old 06-22-2011, 01:11 PM
Oasis Report Please
Was wondering if anybody could please help me out with an Oasis report on an 06 6.0 L that I'm looking to buy.
The VIN is:
1FTSW21P76EB97145
I appreciate anybody's help
Old 06-22-2011, 01:23 PM
Send a message via AIM to FORDF35073PSD
Standard Claims List For Model Year 2006
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 0 2H01 030008 5C3Z 6K682 CA E29 41 196
AWS Claim Key: 1097099 Trx Code: S07 Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:05-JUN-2006 Doc #:27515801
Cust Comments: E29 CUSTOMER STATES CHECK ENGINE LIGHT IS ON
Tech Comments: RAN ENGINE PERFORMANCE DIAGNOSTIC AND PIN POINT TEST, REPLACED TURBOCHARGER, VEINS STICKING
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 14 7N02 0111XX * 7823394 * G07 41 20237
AWS Claim Key: 4898276 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:24-OCT-2007 Doc #:64371902
Cust Comments: INTERIOR TRIM G07 CK CUST SAYS REAR POWER WINDOW INOP
Tech Comments: CP: 7823394 VERIFY COMPLAINT ACCESS SLIDING WINDOW MOTOR CLEAN AND LUBE MOTOR & CABLE WHEEL ASSY CLEAN AND LUBE SLIDER GLASS RUNCHANNEL VERIFY PROPER OPERATION
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 22 2E02 030008 3C3Z 9A274 AA L65 D1 33248
AWS Claim Key: 6381447 Trx Code: S07 Labor Hrs: 3.3
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2008 Doc #:66183503
Cust Comments: DIESEL ENGINE CONCERN CUST STATES HAS FLUID LEAK UNDER HOOD AREA
Tech Comments: ADDED OIL DYE, FOUND FUEL LINE TO RIGHT HEAD CRACKED, R&R FAN AND SHROUD, BELT AND IDLER PULLEY TO GAIN ACCESS, RPELACED FUEL LINE,W ASHED ENGINE AND RETESTED, NPF
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 22 6J01 011404 * 2821812 * L15 33 33248
AWS Claim Key: 6381446 Trx Code: E84 Labor Hrs: 0.1
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2008 Doc #:66183502
Cust Comments: INTERIOR TRIM CUTS STATES RR DOOR HANDLE BROKEN
Tech Comments: CP:7021812 SNAPED COVER BACK ON DOOR
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 22 5N01 110301 5C3Z 3E651 D N25 63 33248
AWS Claim Key: 6381448 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUN-2008 Doc #:66183504
Cust Comments: STEERING SUSPENSION CONCERN CUST STATES LF TIRE BOUNCES ON HIGH SPED TURN
Tech Comments: ROAD TEST VERIFY CONCERN, CHECK AND INSPECT STEERING AND SUSPENSION, REPLACE SHIMMY SHOCK, RETEST VERIFY REPAIR.
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 28 1A04 030008 3C3Z 9P457 AA L65 D1 42392
AWS Claim Key: 7794926 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2008 Doc #:67429402
Cust Comments: DIESEL ENGINE CONCERN CUST STATES HAS LEAK TOP OF ENGINE
Tech Comments: ADD OIL DYE FOUND OIL LEAKING FROM BASE OF CAC TUBE TO MANIFOLD REMOVE ELBOW FOUND BASE OF ELBOW CRACKED REPLACE ELBOW CLEAN ENG NPF
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 28 5A09 050204 E8TZ 4676 B L88 D8 42392
AWS Claim Key: 7774355 Trx Code: 0994D Labor Hrs: 1.4
Dlr Cd-Sub Cd: 02531 - * Name: BOB TOMES FORD Ph: 214-5445000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:25-NOV-2008 Doc #:67429403
Cust Comments: AXLE/DIFFERENTIAL CUST STATES HAS LEAK DIFF AREA
Tech Comments: VERIFY CONCERN, R&R 2 PIECE DRIVESHAFT, REPLACE REAR PINION SEAL, TOP OFF WITH FLUID, VERIFY REPAIR
1FTSW21P76EB97145 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-NOV-2005 02-SEP-2006 152509 USA 57 1B03 030204 3C3Z 6A642 CA D50 55 117911
AWS Claim Key: 9684953 Trx Code: P11 Labor Hrs: 11
Dlr Cd-Sub Cd: 04437 - * Name: COVERT FORD LINCOLN Ph: 512-3454343 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:02-MAY-2011 Doc #:27893701
Cust Comments: CHECK CAUSE WHITE SMOKE STILL COMING OUT OF EXHAUST
Tech Comments: EGR COOLER TEST DEGAS CAP BOTTLE,ENGINE HYDROLOCKED,YES,EVAC COOLANT FROM CYLINDERS,EGR COOLER ON VEHICLE,TEST EGR COOLER OFF VEH TEST,R&R EGR COOLER AND OIL COOLER,ROAD TEST,CHECED FOR BLOWN HEADGASKETS,FLUSH COOLING SYS,LOF,ALL AS PER TSB0983
Old 06-22-2011, 03:18 PM
Thank you, I really appreciate the help. Anything of major concern? I drove the truck and the deltas for the EOT and ECT are only about five degrees separate.
