cts readings
hey guys i was going to my cts today just seeing what all things i can montior. I was wondering where my barometric pressure(BP) sensor and manifold absolute pressure(MAP) should read and how much leeway they can have. Thanks guys Brad
Not to hijack your post 01redcrew, but...
It would be nice if somebody with some authority on the answer could post the ranges of all the monitored features and what they mean...but answer oiredcres's first
exactly what i was thinking but i havent seen anything on here yet unless i over looked it
Baro, MAP and EBP(late build) should all read very close to each other with the key on, engine off. Somewhere around 14.2psi is good
within +/- .2 should be okay that's a good check of sensor functionalitly. those aren't really pids you'd be watching all the time while running |
I have mine set up with the analogue display and I have mine set up with the following:
(These are all unloaded temps, pulling and grades will cause changes) EOT -> Should stay below 230* ECT -> Delta should be less than 15* of the EOT (typically will be higher) driving on level ground at 65 mph after reaching "normal" operating temps (ECT > 190*) FICM -> Should read 48v at KOEO, cranking and at idle TFT -> Should stay below 220* ICP -> Should be greater than 500 psi at all times Some of the other options available for showing include the MPG's, Boost, Speedo, etc I haven't played around with all of the settings and options yet as I've only had mine about a week but that's what I've got my "alarms" set at in my CTS so if I go above them it'll start screaming at me. |
Mine baro is at 14.4. Im watching my ect, eot, ficm volts and battery volts. My truck doesnt seem like its up to full power, but it may be me
. So i was going to try and monitor some sensors to make sure they are working correctly
anyone else
I've got mine showing,
EOT, Engine Oil Temp ECT, Engine Coolant Temp TFT, Tranny Fluid Temp Boost ICP, Injector control pressure. You may wanna toss ICP up and check that out as your driving, mine read 580 warm idle and about 3900 wide open. And heres a for ya too
on my cts my icp is in volts. Is it suppose to be?
there should be another PID that has it in psi as well.
