Ford replacing Half of FICM? - Ford Powerstroke Diesel Forum
Old 06-20-2011, 08:35 AM
Took her in to have the FICM and oil cooler checked this am. Service dep just called with the following
FICM is dropping to 40 V after start. Replacing the upper half of the FICM under warranty. Didn't know you could do just half. Are they cracking these things apart?
Have a 20-25 degree split between EOT and ECT when towing. Oil cooler needs a rebuild kit under warranty. Just had a fluid flush with VC-9 and new fluid two months ago. They will check the EGR cooler while they have it out. Thinking about having them replace the EGR cooler anyway if they say the old one is good. I thought you had to drain the oil for this. Dealer says that they do not have too. Thoughts?
Also stated that the rear diff pinion seal is leaking. Fluid is low. Does $232.00 sound about right?
Stated shocks needed replaced. Declined this one because I can do myself. Any recommendations on some good shocks.
Old 06-20-2011, 08:48 AM
My opinions in Red
FICM is dropping to 40 V after start. Replacing the upper half of the FICM under warranty. Didn't know you could do just half. Are they cracking these things apart? Yes, there is now a separate part number just for the powerside of the FICM
Have a 20-25 degree split between EOT and ECT when towing. Oil cooler needs a rebuild kit under warranty. Just had a fluid flush with VC-9 and new fluid two months ago. They will check the EGR cooler while they have it out. Thinking about having them replace the EGR cooler anyway if they say the old one is good. I thought you had to drain the oil for this. Dealer says that they do not have too. Thoughts?You do not need to drain the oil for Oil cooler or EGR cooler replacement.
Also stated that the rear diff pinion seal is leaking. Fluid is low. Does $232.00 sound about right? Sounds reasonable to me for a shop to do the work
Stated shocks needed replaced. Declined this one because I can do myself. Any recommendations on some good shocks.Bilsteins
Old 06-20-2011, 08:49 AM
information regurgitator
Agreed that even if they won't replace the EGR cooler under warranty, it is best to toss a new one on. Considered the Bulletproof EGR cooler? The dealer may have to wait for your part, but its your truck....
Old 06-20-2011, 08:55 AM
Thanks for the quick reply fellas. Now to see how fast bulletproof can an egr cooler this way.
Old 06-20-2011, 11:29 AM
They should replace both the egr and oil coolers.
Old 06-20-2011, 01:01 PM
I agree but reading the TSB, they are just required to test the egr. They haven't called back yet about the egr cooler.
