Transmission shifting when cold...... - Ford Powerstroke Diesel Forum
Old 06-19-2011, 07:02 PM
Feedback Score: 8 reviews
I'm just curious how YOUR 5R110 shifts when it's cold (say <100*). It seem like mine is reluctant to shift out of 1 and 2 when until its warmed up. I sometimes have to lift off the throttle to get it to shift (just driving normally).
Just curious.
Old 06-19-2011, 07:29 PM
i have the same thing, the easier you go on it the longer it waits to shift it seems like. mine only does it when its real cold out, spring summer and fall i usually never have the problem unless it gets low at night. but thats why in the winter i let my truck run about 10 min or more before i leave
Old 06-20-2011, 02:13 AM
I'm seeing about the same with my '05. first run of the morning 1-2 and 2-3 shift pretty hard and seem to drag out. After mine cycles throught the gears it ususally does great after that. I am also running the old Hyb.Race spartan tune (+170hp I think) had to go back and soften the shifts on the SCT to reduce the potental whip-lash/loss of fillings caused by those 2 shift points anyway.
Old 06-20-2011, 02:22 AM
i run the ol hybrid race tune as a daily to. it shifts hard while the trans is warming up. say under that 100. then its great.
Old 06-20-2011, 02:26 AM
Yeah, once it warms up its great. Better MPG's and neck snapp'n throttle responce.
Old 06-20-2011, 02:31 AM
yep one of my favorite tunes.
Old 06-20-2011, 07:05 AM
I tried Spartan's tune and they made my trans shift so bad I dumped them in a hurry. If you want to try something to help Redline's D6 have the best cold flow properties and the reports I've seen on it said that it really improved the cold behavior of the trans.
Old 06-20-2011, 12:53 PM
huj huj is offline
Feedback Score: 3 reviews
injectors my did the same 05 ex 5 inj replaced under warranty
