90K Maint
Getting ready to do my 90K maint. All set for the oil change and fuel filters. Using only Motorcraft/racor filters. Looking to make sure I have everything right.
Transmission - Doing the pan drop and fill - 5 qts of Mercron trans fluid, external and internal filters Transfer case - 2 qts Mercron Trans Fluid, 8 oz prolong Differentials - Ford synthetic, 3 qts front, 4 qts rear with friction modifier in rear Am I missing something? Thanks for the help. Last edited by arbarlow; 06-19-2011 at 06:34 PM. |
check out my sig for the trans fluid change ~13 quarts.
Do you use fuel additives? diesel kleen white is good and many use it. Mercon sp or lv here is a link for cheap prices on moto and racor filters. Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks http://performancetruckproducts.com/maintenance.html Last edited by smokersteve; 06-19-2011 at 08:29 PM. |
Thanks for the info on the trans fluid change. I'll check it out.
