Replacement Alternator..
Looks like my stock alternator might have crapped out on me. Wanted to see what is the best replacement to go with or just go back with a stock replacement.
Thanks |
These guys make the best alternators. Pricey, though.
DC Power Engineering |
So today I went to Advance Auto to have them test my alternator. The guy told me where the truck has two batteries that he couldn't test it. So is there any way I can test it to see if it is working properly. Also I've been watching the voltage on my Edge Insight and its been reading between mid 12's to low 13's does this sound right or should it be higher.
Thanks |
Another thing you can do is take the alternator out and bring it to advance to have them test it. Thats what I did. Mine went, but it was an intermittent failure, bat light came on took alternator out to test it, tested fine, put back in light came back on, took out to test again and failed this time. Replaced with a reman, ugh wish I coulda replaced it with a new one.
I got one here, 140 amp large case for about $230:
High Output Alternator, 200-250-300-350 Amp Alternators, high output alternators, GM,Ford, Chrysler Dodge Alternators |
Rockauto.com has them from $150 on up. Reman Motorcraft ones from about $220 or so. Your battery voltage should be around 14.5 with the truck running. You need to check the amperage also.
Take it apart and see what failed. I have a 3G on my Mustang and the regulator went out. $5 part!
Voltage regulator went out on mine this winter. I was able to test it just fine in the truck using a meter that has a clamp style for amps. I wish it was as easy as a mustang alt, but its not. Rebuild charge was way over $100.
My truck came with the smaller 110 or 115amp alternator. I bought the larger alt that FOrd puts in the dual alt setup. Its 135amp I believe. I put that in and was able to get 14.5volts at the batteries and easily getting all the amps I need. |
Wouldn't swapping from a 110 to a 140 Amp cause problems if your setup wasn't designed for it? I'm assuming you also installed a large gauge wire along with the alternator to handle the higher Amperage?
