jerky steering on bumpy roads - Ford Powerstroke Diesel Forum
post #1 of 8 Old 06-17-2011, 06:49 PM Thread Starter
amb82's Avatar
Feedback Score: 3 reviews
I have a 4.5 inch icon lift. I noticed when I drive over bad bumps at highway speeds the steering gets jerky. It will jerk into the other lane if i am not paying attention and holding the wheel with two hands. What is the fix for this? This is not a new problem but ready to get this fixed or at least diagnosed
2010 F-250 Cabelas Edition
Sct with Gearhead tunes, 4" afe dpf delete exhaust, leveled on 22's
amb82 is offline
post #2 of 8 Old 06-17-2011, 07:10 PM
headviking's Avatar
Dual steering stabilizers.
If your commin, it's over. If your stroken, it's just started.
2007 F250 6.0L PSD Lariat - Dieselsite Coolant Filter - Bilstein Shocks - Blue fuel pressure upgrade spring - Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - HFCM Water Separator Drain Plug Upgrade - ARP studded - Engine Oil (Rotella syth) - Rear Diff. & Front Axle (Royal Purple)
HeadViking
Helpful Links:
headviking is offline
post #3 of 8 Old 06-17-2011, 07:31 PM
403Grizz's Avatar
Headviking is right, and you may be a little toed in.
2007 F-350 4x4
FULL 4" Flo-Pro w/muffler
SCT Livewire (NEED mount idea's)
2" Leveling Kit w/pro comp ES9000
6.4 Banjo Bolts
High Idle Mod
ELC Coolant with Coolant Filter
Everything Synthetic!!
Coolant filter parts list
403Grizz is offline
post #4 of 8 Old 06-17-2011, 07:32 PM Thread Starter
amb82's Avatar
I figured that was the solution. Thanks for the reply
amb82 is offline
post #5 of 8 Old 06-17-2011, 07:44 PM
I agree, dual stabilizers and an alignment is needed. Even the best quality lifts can/will throw off alignment. Jerky steering can be caused by bigger tires increasing leverage on steering components creating more movement on the steering wheel.
Kobane is offline
post #6 of 8 Old 06-17-2011, 07:48 PM Thread Starter
amb82's Avatar
So your saying this can be fixed with just an alignment? Or is a dual steering stabilizer needed also?
amb82 is offline
post #7 of 8 Old 06-17-2011, 07:58 PM
mah77's Avatar
Try changing your stock steering stabilizer out. I put on a Bilstein, and no more vibration or wobble. Glad I didn't blow my money on duals.
06 F250 FX4 Lariat, 35" Nitto Terra Grapplers, 6" Lift Leveled w/Bilsteins, 4" MBRP TB Exhaust w/Cat Delete, Edge Insight w/EGT Probe & Dash Pod, SCT X3 w/SRL Tune From Matt @ Gearhead, Powerslot Rotors, Hawk Pads, Upgraded Oil Cooler Screen, Upgraded Turbo Drain Tube, Upgraded STC Fitting, Upgraded FPR Spring, CAT ELC Coolant, ARP Head Studs, Opti-Lube XPD, Coolant Filter, 45K Miles
mah77 is offline
post #8 of 8 Old 06-17-2011, 07:59 PM
Steering stabilizer is needed as well, the lift will change your steering geometry even with a drop pitman arm, the leverage is changed, so steering bumps and such will be noticed more. I see you have 35's with wider and taller wheels, the mass involved in the rotating mass is changed as well (weight of tire and wheel), so you will notice more happening with your steering when you go over bumps.
Kobane is offline
