Tea kettle whislte sound
I did a EGR delete about 3000 miles ago. I start the truck up and at idle I can hear a autible high pitched whislte, The only other time I can hear it autibly is when I hit the gas off a stopsign at a certain RPM it seems.
Turbo boosts to 19-21, I dont have a tune to eliminate the EGR yet so I clear the code with my diagnostic code reader. Any help would be appreciated-Mike |
Some say it can be from a bad degas cap not holding the 15psi, in my situation where it was constant and very audible, it was my headgaskets. I noticed i was also dumping coolant in the inside drivers side fender well. Good luck!
Change your degas bottle cap
Its not blowing anything out the cap that I have seen. It sounds like more where the turbo is
Then check for exhaust leaks
I heard of the up pipe cracking. Would this be something the warranty would cover? Truck has 60K on it and was bought 10/31/06....Im just asking in general. I have never had any problems with the truck since I bought it. So just asking. Thanks.
Warranty will cover that
It might not even be cracked....might just be a bad seal
