weird noise from exhaust.. what is it? video included - Ford Powerstroke Diesel Forum
Old 06-17-2011, 04:48 AM
The truck has 88k miles, NEVER had an issue, even before me, according to oasis anyways. Always starts and runs perfectly.
Sometimes though, it will make a weird noise from the exhaust when it is first started for the day. It is not every time, has done it in cold and warm weather. Once its driven a few miles it goes away. My idle isn't fluctuating at all, or at least not enough to show on the stock gauge.
Here's the vid:
VID_20110616_123148.mp4 video by DSMissed - Photobucket
I have straight pipe so it sounds like a jet but you can kinda here the weird noise coming off and on.
Any ideas of what it could be?
Old 06-17-2011, 05:14 AM
It's gotta be something not quite running right. Maybe a bad injector? Have you changed your fuel filters? I would run some Diesel Kleen through it and take it up the highway and mash on it a few times.
Old 06-17-2011, 05:18 AM
I add a little Howes to the fuel every time I fill up. Also just replaced the fuel filters and changed the oil/filter only a few hundred miles ago.
I hope whatever the problem is will show itself soon because I have an extended warranty that will be running out in a few months, but I just don't know. If I get an Edge Insight monitor will it tell me the stats on each injector?
Old 06-17-2011, 06:19 AM
NOT a Democrat
Ok, well I have a horrible ear when it comes to Internet videos. However, to me it does sound like a slight miss.
I agree with above, go after your fuel. Make sure you have good fuel and make sure you have good filters. Switch it up on the diesel additive. I ran out of my opti lub xpd and have to do about 1000 miles of driving this week/weekend. I went and got some Deisel Clean. It surely doesnt lube like my opti lube, you can actually hear the injectors are louder. However, I am in MD this week and we have seen some temps in the low 50s. It sees as if the diesel clean has helped it start better in these cooler mornings.
Old 06-17-2011, 06:21 AM
That's where the 2-cycle oil will help. I never use DK without adding a bit of 2-cycle oil into the mix.
Old 06-17-2011, 06:28 AM
NOT a Democrat
Good point! I just picked up two bottles so I wasnt runing naked this week! lol I am about half way with my trip so I will stop in and get some!
Old 06-17-2011, 08:25 AM
Ok, so you guys are basically saying to add a bit of 2 cycle oil in the fuel, along with some Diesel Kleen? How much would you say to add? I have some winter DK left, I'll put that in since I'm out of Howes.
It has actually done the noise thing since I bought it last September. Like I said, not every time it cold starts, and sometimes it does it worse than others.
I sure hope this isn't the start of injector issues!! I love this truck!
Old 06-17-2011, 01:26 PM
I just got done driving it and for the first time since I owned it I mashed the pedal, and the first time I did it felt pretty doggy, but then I did it again, once in 2nd and once in 3rd and it felt like it got a little more pep to it, but could also be my imagination.
