new 2007 powersroke owner
Just got a 2007 f350 drw anyone know in the detroit metro area have an exhaust on there 6.0 that i can hear in person. I also have a line on a edge ev. tuner that i was thinking about picking up I tow on the weekends and daily drive the truck do you think ill have any issues? truck has 63000 on it just did coolant flush oil change tranny this weekedn and rearend. also i have done some searching but didnt find much after a week are there any to do cheeper mods to keep this truck alive i plan n keeping it for the long hall(exam. fuel system dummy plugs nit sure what those are and stands i saw somewere) thanks for the help in advance. i also have a coolant filter and oil filter bypass on the way
I havnt heard too much good on the edge ev tuner. Theres a good bit of threads on which tuner is best for these trucks and most will tell you to get a SCT with custom tunes. The main reason is because the sct tunes your transmission to go with the tunes where as the other tuners dont and that will shorten the life of your trans.
For starters pick up an Edge insight cts or cs to moniter your trucks vitals, most importantly the engine coolant temp (ect) and engine oil temp (eot). Temperatures greater than 15 degrees need attention asap or more problems will come. Order of upgrades i would recommend: cts or cs, 6.4 fuel banjos, upgraded fuel regulator spring then pick up a sct tuner. Things to consider about owning a 6.0L |
welcome to the site! 06dzl is correct. the edge doesnt tune for the trans and you will tear the truck up sooner esp. if you tow.
Coolant flush? Hmmm......................
I talked with edge today way say that there tuner does have adjust for shift points and shift firmness. I can get one new in the box from a shop a friend works at for dirty cheep. the sct sounds like were it is but i dont want buy that tunner then a edge gauge to monitor. thanks for the help guys
Shift firmness and points are one thing, but true tuning of the pressures and lock up on the trans are something else. A shift kit does basically what the edge does
Sent from my SCH-I500 using AutoGuide App |
