HELP COOLANT LEAK.....im stranded
Guys I have a coolant leak from the front of the motor on the driverside....I parked at brothers house and came back an hour later and there is half a gallon or so on the ground. I cant see where its coming from, I did a coolant flush a few weeks back, and replaced the thermastat. Truck has been running normal temps, first time it has leaked. It looks like its coming below the thermastat area.....any ideas?
Check the clamp on the hose coming from your thermostat. When I changed mine out, the clamp lost enough tension to drip coolant like you describe.
Did you replace the clamp or just reposition? Did you loose a lot, like a 3 foot puddle in a few hours? |
Actually, I realized I had a pic of it and you can just make out the puddle of coolant under the truck. Maybe not a 3 foot puddle, but you can tell it's a decent leak.
Nah, not likely the water pump. You might not have gotten the coolant temps (and therefore pressure) up to where the leak was manifesting itself. After my thermostat change, I drove it around the block to confirm no leaks. The next day, I towed the setup you see in the pic and when I stopped, I ended up with the puddle.
Best of luck and keep us posted. |
update: I drove truck 250 miles or so this weekend, and leak has disapeared. Repositioning of the clamp on the thermastat must have been the issue.
NOTE: Myself and Evil Eye now have both performed flushs/thermastat change and both had a leak at the hose clamp area after the flush. It might be a good idea for others to also keep an eye on this clamp after performing a flush/tstat change |
Seen that leak before.... Possible EGR cooler hose from egr cooler to oil cooler?
