Vacuum Pump Passenger Side?? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 06-16-2011, 01:19 PM Thread Starter
DEESLVRGN's Avatar
I noticed the other day, after my injectors stop clicking, there was a humming/running noise, so upon further looking, I saw the vacuum pump running, doesnt shut off, this never happened till after the dummy plugs were fixed. I may have possibly nudged the connector and plugged it "back" in?
Anyways, I don't think it should be running constantly as it never did before?
2006 F350 CC LB SRW 4X4
-Goose Neck
-updated STC, Dummy Plugs, standpipes, oil feed line, "Blue" fuel pressure spring
-SCT Livewire TS w/Pyro "Looney Tuned"
-RECON smoked clearance lights, black OEM grill
-Kitty and Muffler delete
-POWERMAX TURBO
-58V FICM from QuickTricks
-Huge WISHLIST
DEESLVRGN is offline
post #2 of 11 Old 06-17-2011, 03:36 AM
huj
Feedback Score: 3 reviews
you have vacuum leak follow tthe hoses check make sure that they are hook up
huj is offline
post #3 of 11 Old 06-17-2011, 01:21 PM Thread Starter
DEESLVRGN's Avatar
All my hoses are hooked up, to my knowledge it runs the A/C, EGR valve and 4wd. I looked all over the transfer case, cant even find a hose that would go that way??? is it possibly a bad pump?
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #4 of 11 Old 06-17-2011, 01:33 PM Thread Starter
DEESLVRGN's Avatar
Also, my A/c, 4WD and EGR valve all work
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #5 of 11 Old 06-17-2011, 01:45 PM
Fox'sFord's Avatar
Egr has nothing to do with your vacuum system. Are you getting air from all vents or only from your defrost?
Fox'sFord is offline
post #6 of 11 Old 06-17-2011, 01:48 PM Thread Starter
DEESLVRGN's Avatar
only defrost
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #7 of 11 Old 06-17-2011, 01:55 PM
Fox'sFord's Avatar
You've got a leak my friend. Start with the hubs if all your lines are hooked up. The pump runs on demand, so if there is a leak it will run constant and you only get air from the defrost vents. Use the little google search function in the top left, leaky hubs are common on these trucks.
post #8 of 11 Old 06-17-2011, 01:58 PM Thread Starter
DEESLVRGN's Avatar
is it quite visible with the wheels on?
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #9 of 11 Old 06-17-2011, 02:01 PM Thread Starter
DEESLVRGN's Avatar
I do have manual hubs if that matters?
-Goose Neck
-POWERMAX TURBO
-Huge WISHLIST
post #10 of 11 Old 06-17-2011, 02:12 PM
Fox'sFord's Avatar
Start simple, recheck the condition of all your lines and connections, then put it in 4x4 and check the lines for vacuum.
Manual hubs but push button on the dash right?
Tags
a/c , transfer case , vaccum pump
