How do I know which one I have? Or is one the rear and the other the front... :dunno:
As for the drain plug ohh yea it's nice. I had a Nissan Titan and it had a drain plugs in both axles and it was sweet. Swapping out the fluid was very easy.
Yes, I have used those before. But for the common man, why can't they just put a drain plug in? I know it's nice to remove the cover to check wear and stuff, but I bet fluids would get changed much more often if there was a drain. I know mine would...
Drill a hole in the cover.grind off paint, weld a nut on the outside then put a bolt in with a washer and some silicone. I did the same on my old chevy' for a filler also.
Yea my problem with that solution is that it will still leave a good bit of the old oil in the diff along with any metal shavings. To me that is not worth the trouble when I can just pop off the cover and get all that junk out.
My Titan had a drain plug in the center of the bottom. It looked like the bottom of the an oil drain pan. Worked great!
Mobil1 makes a 75w-90 for the front and a 75w-140 for the rear axle. It is a synthetic that comes WITH the additives for the LSD if your truck is equipped. Price is like $11 for the 90 and $19 for the 140. When I do mine, that's what I'll be using.
I completed the fluid change for both axles this weekend. Laying up underneath the truck with it on ramps makes for a tough job. But I'm glad I completed it. I ended up going to the local Ford dealer and buying the Motorcraft LSD fluid and putting that in the rear along with the Amsoil oil.
I used the recommendation from Amsoil.com. I think it was 7 pints for the rear and 6.4 for the front. In both diffs I found when I got to the recommended amount just a little started to come back out of the fill plug. I let it drip for a bit and then capped it.
Related Threads
Ford Powerstroke Diesel Forum
5.4M posts
265.8K members
Since 2005
