AC Question sounds like a leak after I shut the truck off.
Like the title states after I shut the truck off I opened the hood to check my oil and coolant level and there was a his coming from the AC components. It still blows cold so I don't think I am looking Freon but I have never heard this before. Thank for any and all help.
This is normal. Enjoy your cool truck. You are hearing the residual pressure in the high pressure side going through the metering device into the low pressure side of the system. Oh, ya don't worry about the little puddle of fresh water under the passanger side of the truck, thats normal too.
Yeap, thats right. its just the system equalizing out.
Your house does the same thing if you go outside and listen to it. |
you guys seem to know about a/c, How cold should it be in 100 degree weather?
On high-idle or moving down the highway mine will freeze you out.
[QUOTE=HAM_RADIO_MAN;2540786]On high-idle or moving down the highway mine will freeze you out.[/QUO whats is it at when your idling? and how did you grt it that cold
My vent temp is about 40 deg. For many different reasons you can’t expect stellar performance at idle. There is less air to cool the condenser and the compressor isn’t moving as much Freon. Make sure you wash the bugs and crud out of the condenser on your truck and house for that matter. A clean condenser equals a happy compressor. I don’t think you have a cabin air filter , but if you do make sure that’s in good condition. You will need to have the correct amount of Freon in your truck. The temp scale on the gauges tells you roughly what temperature the Freon is evaporating and condensing at. You want your evaporator to be a little above freezing say 33-36 degrees as a general rule your condensing temp should be 30 to 40 degrees above the outdoor temp. I would suggest taking these measurements at high Idle because that engine speed is closer to the real world operation condition of your tuck. So, that means now is a great time to finally do that high idle mod. These are rule of thumb generalizations and I am sure all the professional ac guys out there are shrieking in horror. I am a refrigeration mechanic so I know that I have only touched on the high spots, but the idea here is to give the shade tree guys a fighting chance to stay cool without blowing their truck up. One very important thing to know is, if your system is empty you must use a quality vacuum pump to remove the air before you recharge. If you don’t you will have no cooling sky-high head pressure and wonder why? Ok, so use a vacuum pump. Take 15 min with Google and learn how a basic refrigeration cyle works if you don't already know and that will clear up a lot of the smoke and majic. Stay cool!!
Last edited by HAM_RADIO_MAN; 06-15-2011 at 07:17 PM. Reason: attempt to fix some of my poor use of english language and spelling |
