Door keypad.......... - Ford Powerstroke Diesel Forum
post #1 of 15 Old 06-14-2011, 02:45 PM Thread Starter
Is there a battery in the door keypad (from the factory)? Mine seems to work erratically sometimes, like a battery is low. Is it powered by the vehicle battery?
Aussiekeeper is offline
post #2 of 15 Old 06-14-2011, 03:12 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
Feedback Score: 3 reviews
If the key pad is just about flush with the door skin, it's a factory install. If the key pad is about 1/2" higher than the door skin, it's a dealer install.
I know on the dealer install units they have a separate battery behind the key pad. I'm not sure how the factory installed key pad is powered.
I'm only going by what I've read on this site. I have the dealer installed unit according to one of the Ford techs on here.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 15 Old 06-14-2011, 03:46 PM
Dante04SRT's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Got pics to show each style?
-Brian
2005 F350 6.0 CC/SB Lariat 4x4
EGR Delete
ARP Studs
All updated Ford internals
Edge Insight CTS2
Swamp's 58V FICM
SCT X3
TGC 2.5" Level Kit
Zerex EC-1 ELC
08+ Step Tailgate
08+ All Power Mirrors (Factory Functions, too)
2011 Rear Bumper
B&W Turnover Ball
8oz Stanadyne Performance w/each fillup
Dante04SRT is offline
post #4 of 15 Old 06-14-2011, 03:49 PM
Powerstroke Techie
Lilpooh's Avatar
Quoted: 10 Post(s)
No I don't, but you could always google it. I only researched the info just incase I ever ran into issues.
Lilpooh is offline
post #5 of 15 Old 06-14-2011, 04:47 PM Thread Starter
I ordered it with the truck, so it is a factory unit.
post #6 of 15 Old 06-14-2011, 04:47 PM
rem1981's Avatar
The factory installed keypad is wired into the truck. The dealer installed one is not. It's basically a key fob stuck to your door.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #7 of 15 Old 06-14-2011, 04:56 PM Thread Starter
Good to know..........I'll put the chisel away now................
post #8 of 15 Old 06-14-2011, 05:14 PM
Dante04SRT's Avatar
Quoted: 2 Post(s)
I'm curious about this whole thing now..... I'd have to assume my F350's is factory installed, considering the "brain box" location WAAAAAYYY up in the dash.
I have seen from different years, the keypad is in different locations. I've seen some like my '05 in FRONT of the door handle, and I've seen others (02-04ish) that have 'em ABOVE the handles.
-Brian
EGR Delete
ARP Studs
Edge Insight CTS2
Swamp's 58V FICM
SCT X3
TGC 2.5" Level Kit
Zerex EC-1 ELC
08+ Step Tailgate
2011 Rear Bumper
B&W Turnover Ball
post #9 of 15 Old 06-14-2011, 05:32 PM
anything after 04 so 05 and newer is ran off the truck battery. 04 and older they have a battery in the key pad.
ASE Master Certified Technician
04 Powerstroke lovin it
thenubsterman is offline
post #10 of 15 Old 06-14-2011, 05:37 PM
rem1981's Avatar
This link shows pics of a dealer installed one, and has some info. See if this helps. (I'm on my phone, so I can't insert the link...you may have to copy and paste)
http://www.frontiernet.net/~jcray/04...KeypadBatt.pdf
rem1981 is offline
