Transfer Case Fluid
Am I ok using Amzoil sythetic ATF?
Oh, and would it be the same for an 03 Gasser too? Both mine and my dads truck needs changed. Thanks
Any Mercon (V) rated ATF will work. I'd assume the gassers are the same.
I changed my transfer case fluid on Sunday - Took about 2 1/3 quarts of Royal Purple Max ATF. |
Do they have any syncros in them? If so I definatly would run what Ford tells you to. In a transmission at least, running anything but what they recomend will screw with the whole thing. I switched to synthetic ATF in my trans
Shifted like crap. switched back to dino ATF, shifted like a champ |
yup just use a good synthetic ATF. 6 quarts will do both trucks.
Cool. Thanks Guys. Yup, I will grab a 6 pack!
As for the trans, yes, run only what Ford tells you to. |
I was mostly talking synthetic vs. dyno ATF,
Yup! I have it in my Tcase. for over 30,000 miles. ~5,000 of 4x4.
