head gaskets? - Ford Powerstroke Diesel Forum
Old 06-12-2011, 03:36 PM
head gaskets?
fixing to do arp studs and egr delete. need info on which head gaskets to use. Ford or Black oxnyix? all info appre. thanks
Old 06-12-2011, 03:38 PM
From what I've read, its best to go with the Ford ones.
Old 06-12-2011, 08:13 PM
I used black onyx. Works just fine.
Old 06-12-2011, 09:01 PM
I used Victor Reinz, ive read they are the same but cheaper.
Old 06-12-2011, 10:25 PM
I don't think it really matters much what you pick. Honestly, the reason the stock gasket fails in the first place is due to the junk torque-to-yield head bolts. But ARPs are not going to stretch. The black onyx gaskets have a sealant coating over the entire gasket, so theoretically, they should seal a bit better. But unless you are building a high horsepower engine, I wouldn't expect either one to fail again, unless for some other reason (EGR cooler or oil cooler). That's just my opinion.
Old 06-13-2011, 07:35 AM
There is evidence of issues with the BO/VR gaskets and some vendors have quit using them.. Stick with the Ford gaskets. If they can hold all the power Shawn Ellerton makes they'll work for you.
