2006 CCLB Tie Rod Replacement - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-08-2011, 08:49 AM Thread Starter
astroinhouston's Avatar
Truck was in the shop to have the alignment readjusted. Just got a call stating both the front left and right outer tie rods need to be replaced to the tune of $500 all in.
I have never jacked with anything suspenion in my life. How difficult would this repair be to do on my own? Is $500 worth it? I don't even know how much tie rods are outside of this quote, they are charging $335 for parts and the rest in labor.
Should I go with OEM parts or are there better aftermarket options? I am heading on a 600 mile round trip this weekend, not knowing a thing on tie rods, is it critical to get them done before the trip(dealer wins in this scenario) or could it wait until I can get to it in 10 days and 600 miles later?
Thanks for any help or info. Truck is 4WD if that makes a difference.
astroinhouston is offline
post #2 of 22 Old 06-08-2011, 08:53 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i am not sure about labor but also maybe look into moog tie rod ends. I have heard they are better than OEM. Also i would get it done before your trip. You dont want to have a tie rod fail!
08 F350 cc/sb 4X4
h&s minimaxx, 5" flo pro, 4" down pipe, no limit cold air intake, dirty diesel EGR delete with intake elbow, 6.0 exhaust manifolds, custom up pipes, ported intake manifold, Apex 71mm LP turbo, Rudy's cold side pipe, diesel site coolant and transmission filter, diesel site intercooler boots, ccv mod, bilstein shocks, gogo dd solenoid, HID lights, Airdog II 165, PMF traction bars, PMF drag link, moshimoto aluminum radiator
04hdfatboy is offline
post #3 of 22 Old 06-08-2011, 09:20 AM Thread Starter
Thanks for the reminder on Moog, I always here people on the site talk about that brand.
Man youtube is becoming my 2nd favorite site, found a video doing a replacement, and looks pretty darn easy. So I am going to do that before I head out.
In addition to the tie rod replacement, is there anything else I should do at the same time? I always here tie rod and ball joint in the same sentence, should I be doing anything else here? Guess it's a great time to learn the steering system on this truck...lol.
post #4 of 22 Old 06-08-2011, 09:22 AM
04hdfatboy's Avatar
Quoted: 4 Post(s)
might want to check your track bar bushings while you are there. Check your ball joints for wear. If you do your ball joints might as well do the axle u-joints because they are right there also. Its never ending fun lol
08 F350 cc/sb 4X4
post #5 of 22 Old 06-08-2011, 12:19 PM Thread Starter
Just picked up the truck. Ball joints are dry/cracking, so ordered tie rods and ball joints already. I agree with the u joint idea after seeing where they are in the videos, seems like a decent maintenance item for less than $100.
I can't seem to find Moog U-Joints, do they make them? If not, any idea on a decent brand for the u-joint?
post #6 of 22 Old 06-08-2011, 12:22 PM
04hdfatboy's Avatar
Quoted: 4 Post(s)
i recommend the spicer u joints that are not greaseable because they are stronger. You can contact George at 8 lug truck gear and he can get you the correct u-joints. I think any part store can get moog tie rod ends.
08 F350 cc/sb 4X4
post #7 of 22 Old 06-09-2011, 08:00 AM Thread Starter
Does anyone have an exploded view of the suspensions for the 6.0?
post #8 of 22 Old 06-09-2011, 08:22 AM
Just the other day I did both inner and both outer tie rod/drag link ends. I ordered MOOG stuff because everyone swore they had grease fittings. Well not one of the parts has a grease fitting in it. So just make sure you know exactly what you order. And as for ball joints there's a couple really usefull videos on youtube if you're not sure how to do em.
1chadsin is offline
post #9 of 22 Old 06-09-2011, 08:24 AM
This is the one I used when ordering parts. Its from Ford Parts Giant. But I ordered them from RockAuto since they were cheaper.
1chadsin is offline
post #10 of 22 Old 06-09-2011, 09:35 AM Thread Starter
Thanks for the snapshot, big help just on how things link together.
Do I need any seals, orings, gaskets for any of this stuff? Does everything come with every part?
As of now, I have the following heading my way:
Moog Drag Link #DS80749
Moog Outer Tie Rod ES80755
Moog Outer Tie Rod ES80754
2 Moog Upper Ball Joint s K80026
2 Moog Lower Ball Joints K8607T
2 Spicer axle u-joins 1480WJ
Will address the track bar bushings when I get everything off, and pick them up if needed locally. Anything else I should add to this for preventative maintenance, or anything else i could encouter/should check as I am doing this that is common to fail? Also, does anyone know what size socket to get the rotor off?
Trip this weekend got cancelled (WOOHOO) get to do this, and install the exhaust I just ordered this weekend. Should be interesting.
