AE Wont connect to PCM - Ford Powerstroke Diesel Forum
post #1 of 18 Old 06-06-2011, 10:12 PM Thread Starter
Beef52751's Avatar
i am trying to check my truck for codes and look at a couple other things but i cant get the AE to connect to the truck. I have the Enhanced Ford Bundle but it wont connect, i set it at J1850 PMW and OBDII Compliant and it wont connect to the truck. when i use NON OBDII Compliant it will connect to the truck but i cant open generic powertrain, Enhanced Can, or any other option. WTH is wrong with this thing!?!?!? or what m i doing wrong?!?!?
Thanks
Beef
2006 CCSB F-250 King Ranch FX4 6.0
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
Boost, Pyro, and Fuel Pressure Gauges
Beef52751 is offline
post #2 of 18 Old 06-06-2011, 10:26 PM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Is this the first time you used it?
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #3 of 18 Old 06-06-2011, 10:35 PM Thread Starter
Beef52751's Avatar
me yes, but my brother has used it on both my 03 and his 03 6.0s
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
post #4 of 18 Old 06-06-2011, 10:45 PM
Powerstroke Techie
Lilpooh's Avatar
Alot of times the Auto Detect don't work, you need to manually select CAN support. While still hooked to truck, top left of screen "disconnect" from vehicle. Then goto "communications Configuation" to manually select the CAN interface. Then I believe, I went back to "connect to vehicle". A window pops up going thru the check list, then another window pops up checking for sensor configuration. After that, it will ask you if you want to check for codes "All", "Current","None".
It's hard to remember without it in front of me, but it sounds like you were trying to use the J1850, when you should be using CAN.
Lilpooh is offline
post #5 of 18 Old 06-06-2011, 10:50 PM
Powerstroke Techie
Lilpooh's Avatar
When you get it working, here are some Tips & Tricks.
AutoEnginuity Tips or Tricks
This is also handy.
http://forum.gopowerhungry.com/autoe...stic-software/
Lilpooh is offline
post #6 of 18 Old 06-07-2011, 05:12 AM
Davey~do's Avatar
That sounds about like the right procedure right off the top of my head as well.
Davey~do is offline
post #7 of 18 Old 06-07-2011, 07:07 AM
Slacker
Evil Eye's Avatar
Quoted: 193 Post(s)
Feedback Score: 4 reviews
Damn, you remembered that without it being in front of you.... I must be getting old...
That sounds right. I think F4 is the communications configuration, so you can just press F4 and it brings up the screen to change it to CAN.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 18 Old 06-07-2011, 07:41 AM
Powerstroke Techie
Lilpooh's Avatar
Originally Posted by Evil Eye View Post
Damn, you remembered that without it being in front of you.... I must be getting old... CAN.
Ha Ha!! My memory won't be here much longer, I turn 40 in August, they say it's all down hill after that!! LOL!
Lilpooh is offline
post #9 of 18 Old 06-07-2011, 01:44 PM Thread Starter
Beef52751's Avatar
Ok, i selected CAN and OBDII Non Compliant, i got another popup that had the selections, i entered Ford, 2003, Powerstroke 6.0 and Enhanced Powertrain and get a message that says
"Communication could not be established with the controller. Check the Connection or Validate the vehicle has support for the controller."
Now what???
Thanks for the help Guys!!!
S&B Intake
Zoodad
Fog Light Mod
T6 5W-40
post #10 of 18 Old 06-07-2011, 02:31 PM
Powerstroke Techie
Lilpooh's Avatar
I believe you want to use CAN and OBDII Compliant.
If you don't have the user manual, you can bring it up on your PC.
Here's the link from Autoenginuity.
http://www.autoenginuity.com/dloads/...user_guide.pdf
Does all three lights come on in the Pro-Line connector? The Pro-line connector is what you plug into the OBDII port. There should be red, yellow, and green showing. If not you have a bad connection. Check your cigarette lighter, it uses the same fuse as the OBDII power supply.
Also there are people out in the Internet who make copies of the disk that are no good. The disk and hardware have to be original to use the activation code when the PC was set up.
Lilpooh is offline
