Turbo shut down noise - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-02-2011, 08:37 PM Thread Starter
2005 F250, 79,000 miles, super clean Oasis, everything functioning great...but I have one concern:
Upon shut down...I hear the typical turbo spool down noises as I would expect to hear. But it seems right before it reaches zero rotation...say 2 seconds before stop...it changes sound and gets "noisy" in my opinion. Not whistle noise...but something else. Like hissing or constant huffing??? It definately changes tone.
Would this be normal or should shut-down be "silent" once down to low rpms on the turbine shaft? I'm guessing the variable vanes are doing something at the end making this sound...which I'm calling harmless.
I'm only familiar with non-variable turbos on Cummins and Duramax engines. Perhaps I need to go listen to another 6.0L to compare.
neil is offline
post #2 of 4 Old 06-03-2011, 10:27 AM
not really sure, bud. here's a bump though. i'm subscribed as my 05 has been getting a bit noisier as well at times. jl
'05 F250 CC - short bed 4X4, 6.0 Automatic. Stock with RanchHand deerslayer up front
jlandgraf is offline
post #3 of 4 Old 06-03-2011, 11:18 AM
Acidsniper's Avatar
Sounds normal to me, sounds just like an aircraft propeller right before it stops rotating, it's a clear change in pitch of the sound of the rotor, in this case the turbo vanes, it's caused due to the speed at the trailing edge of the blades moving slower than supersonic. The faster the tips of the blades go the more high pitched a sound it will give (it's why turbos "scream" at high RPMs and why the 03's scream louder than the 05+ due to the fewer and larger turbo blades).
Yay my $60k worthless Aeronautical Engineering degree finally came in handy! haha
~JW aka "Acidsniper"
2006 King Ranch CCSB FX4
MBRP 5" Turbo Back
DC Power 270 Amp Alternator
Airaid CAI
Edge CTS
Bushwackers
Recon mirror lenses
Dieselsite Coolant Filter
T6 & Rev-X
Proud Navy Vet
Acidsniper is offline
post #4 of 4 Old 06-03-2011, 03:19 PM Thread Starter
I don't think its a turbo going out...but rather a noise that may be common to the VGT on this truck (I'm hoping). It's not really loud enough or bad enough to sound like something in failure mode. Its just now what I expected, having heard many turbos spool down at shutoff. I pay close attention to too many things all the time.
I seem to have an acute sense of hearing at times. Perhaps too sensitive.
I'll have to get someone to shut the truck down while I'm right up there near the turbo so I can pinpoint the sound. Probably ought to take the intake tract off and check the inducer wheel too for any obvious signs of a problem.
neil is offline
