Fuel pressure gauge & New injectors??? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 06-02-2011, 09:18 PM Thread Starter
ricearoni1024's Avatar
First does this fuel pressure gauge kit come with everything I need to have the correct setup to monitor my fuel pressure? Also should I buy the new spring or just do the BB mod after I get the gauge in?
2nd question with new injectors, what is the stock size? And whats the best size to go to keeping with stock fuel system and stock turbo or the garret powermax? Thanks for the help!
F350 LB.
Afe stage II.
Banks monster 4".
Edge Insight.
Sct/Tunes from Matt @ Gearhead.
PHP-ECM/FICM.
Bushwhacker pocket style flares.
DDM HID's 8k lows-6k High beams.
6" fabtech 4.0 dirtlogic lift.
ricearoni1024 is offline
post #2 of 4 Old 06-02-2011, 09:31 PM
If you get this 6.0L Fuel Pressure Adapter it has what you need to go into the test port never do the BB mod without the gauge, i would get the Kit.
On the 2 guestion someone will have to help you on that one
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #3 of 4 Old 06-02-2011, 09:54 PM Thread Starter
2 stroker
Thanks for the info! Also saw in your sig it says your insight does the fuel pressure, i have the insight as well what all do you need for that? or is that only on the newer insights?
F350 LB.
Afe stage II.
Banks monster 4".
Edge Insight.
PHP-ECM/FICM.
post #4 of 4 Old 06-02-2011, 10:14 PM
It is on the new Insights but the problem is you have to get all the other junk to hook it up so when it comes to $$$$ it is not there plus i think you have one less thing to view on the edge that is important i like the fuel on the column
2 stroker
Delo ELC Coolant
3" dp 4" exhaust
Tymar Intake
