Originally Posted by Daxman
So i've had my truck for about 3 weeks now and i have been dealing with this starting when cold issue. Took it to autozone today and load tested the batteries and they are good. While i was there im starting to hear this tapping sound coming from the right side of the engine, sounds like its under the injector. This is definatley a lifter issue. Im wondering if maybe i have trash in the lifters or something. We dont abuse the truck at all, but i have been known to open it up a time or too. Im wondering if these are self adjusting lifters and if there is trash in there, how do i get it out ?
If you are have cold start problems most of the time it is the FICM this tell the injectors what they need to know cost of $300 to $1100 and new batteries about $220, so what year truck plus i would change the batteries Ford 100 month here
Ford, Lincoln & Mercury Service Coupons | Save Money on Your Next Service Appointment | FLMowner.com
Do you have fresh fuel filter, Ford i hope run Syn oil 5w40 and Ford oil filter you can get them at Walmart 2016 Motorcraft you might try Rev-x 2 bottles with fresh oil they say it works wonders and cetane boost in the fuel i use the Ford stuff
Start simple did you check for codes when you were at Autozone
Here is the check for the FICM
2 stroker
