Turbo getting slower - Ford Powerstroke Diesel Forum
post #1 of 26 Old 06-01-2011, 06:50 AM Thread Starter
nylyon's Avatar
I'm wondering if I need to clean my turbo again. It's taking longer and longer to spool, my EGT's seem higher, and my boost is down from 21 to 18. I don't have any new exhaust leaks (Y-Pipe and Up-Pipe were replaced recently).
Been reading up on the VGT Solenoid and cleaning doesn't seem to do much.
Anyone interested in an 03 Turbo trade
- Karl
2003 F-250 Crew Cab Short Bed Lariat PSD 6.0 Automatic FX4 Edge Insight with EGT Probe. Coolant Filter. All 6.0's need gauges
nylyon is offline
post #2 of 26 Old 06-01-2011, 06:59 AM
dazdillenger's Avatar
Feedback Score: 7 reviews
where is brewster? Id be happy to put a scanner on it and take it for a spin.
dazdillenger is offline
post #3 of 26 Old 06-01-2011, 07:03 AM Thread Starter
nylyon's Avatar
It's the southeast corner of Putnam county, just north of Westchester and boarders Danbury, CT
- Karl
nylyon is offline
post #4 of 26 Old 06-01-2011, 07:05 AM
3.5hrs. Too bad you're not closer. PM mw id you are ever near cooperstown. Be happy to lend a hand.
post #5 of 26 Old 06-01-2011, 07:29 AM
DesertSmoker's Avatar
Sorry to hear that. I'm having the same problem.
2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #6 of 26 Old 06-01-2011, 07:34 AM
diablos30's Avatar
Quoted: 31 Post(s)
are both of your boots good?
diablos30 is offline
post #7 of 26 Old 06-01-2011, 07:42 AM Thread Starter
nylyon's Avatar
Turbo to IC Hot boot is new. Others inspected fine. At one point yesterday, I hit the throttle, the boost jumped to 21 as shown on the insight and the truck took off like a bat out of he11
- Karl
nylyon is offline
post #8 of 26 Old 06-01-2011, 07:42 AM
Powerstroke Techie
Lilpooh's Avatar
Feedback Score: 3 reviews
Clean the EBP tube on the driver side exhaust manifoild. The VGT actuator gets some of it's commands based on the EBP sensor, if the tube is getting blocked from soot it can give false readings.
2004 F350 CC DRW King Ranch
X-3 tunes by DJ'S,QT,GH,ID. Gryphon FICM tunes, ARP studs,Stage 1turbo,ATS coolant recirc lines,Swamp's 48v ficm,coolant filter,AD2,Snow Perf stage II,EGR delete,4" turbo back straight pipe,S&Bintake,Quad "A" pillar autometer gauges,Suncoast Tri Disk Conv.,Billet input shaft,Suncoast superduty rebuild kit,Trans-go shift kit,Mag-Hytec trans pan,CFM+ elbow,ccv mod,15K reese 5er,17" LCD TV/DVD,Cobra 29 Nitewatch CB
Lilpooh is offline
post #9 of 26 Old 06-01-2011, 07:44 AM
Yes all boots are good. I am hoping that I find a big exhaust leak off the Y or up pipe to give me my low boost. I am going to clean the turbo too.
post #10 of 26 Old 06-01-2011, 07:45 AM Thread Starter
nylyon's Avatar
I thought that the 2003's had inferred EBP, and the EBP sensor was no longer used?
- Karl
nylyon is offline
