egr delete - Ford Powerstroke Diesel Forum
Old 05-31-2011, 05:24 PM
egr delete
Going to do an EGR delete on my truck soon. I have 108k miles, and pretty much bone stock except for my lift and tires. Was just wondering if their was anything else that I should do while I'm in? Also should I get a tuner (edge cts) or can I go a different route? Thanks in advance.
Old 05-31-2011, 05:28 PM
Feedback Score: 3 reviews
Get gauges/monitor first to check your ECT and EOT delta, this way you'll know if you gotta replace the oil cooler while your in there.
SCT X-3 with custom tunes is the only way to go with the 6.0, most guys use either the ScangaugeII or Edge Insight CS/CTS for gauges.
Old 06-01-2011, 06:03 AM
Yep, coolant flush, egr delete, rebuild oil cooler, refill with ELC coolant.
Don't do any of it till you have a monitoring solution and know what condition your truck is in. The dollars you save will probably be your own.
Old 06-01-2011, 07:00 AM
What year is the truck and what do you do to keep the check engine light off after a EGR delete? Heard there are tuners that can keep the light off, is that true?
Old 06-01-2011, 07:04 AM
Yes.
Old 06-01-2011, 07:05 AM
Early 6.0's wont throw a Code. Some 05's will. My 06 threw a code for "low flow" and will need to be tuned out.
I used the kit where you get a cap for the exhaust pipe and leave the EGR where its at plugged in. I just did a cheapy Ebay kit.
Old 06-01-2011, 07:59 AM
Why either the Edge CS or the ScanGauge II for monitoring? Why not the SCT DashScan? Seems like everyone likes the SCT for tuning...and the Edge CS/CTS for monitoring...but I never hear much about the DashScan for monitoring EOT/ECT etc.
Old 06-01-2011, 08:12 AM
The Dashscan is out dated and don't monitor as much as the ScangaugeII or CS/CTS. Dashscan won't do FICM volts, VGT cycle, EGR cycle, ICP,IPR, ect,ect.
Old 06-01-2011, 08:28 AM
No to Dashscan!!! Hate to say it but that was not one of SCT's best pieces of work. The ScanGuage II is fantastic for data monitoring.
Old 06-01-2011, 08:30 AM
Just saw a post this morning about a guy that had a 2004 6.0 and it set a check engine light for EGR insufficient flow after installing a delete. So the rule of only 06 and up and deletes isnt always true. IMO
