Engine coolant temps.....Seems high to me - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-30-2011, 04:40 PM Thread Starter
I just did a 500 mile trip hauling my rzr and about another 800lbs of payload (2000lbs total). Truck ran great, but I spent a lot of time watching my ECTs/EOTs on my Edge CTS. My Delta was never more then 11F, and most the time in the 9F range. Today when coming home I was averaging 70-75mph and ym ECTs were 212-216F on the CTS. I had an ID tow tune on when hauling. I had the AC on, and it was about 80F outside. This seemed really hot to me, but maybe that is normal. Do I have anything I should worry about? What does everyone else see in conditions like this?
barry1me is offline
post #2 of 11 Old 05-30-2011, 04:47 PM
2003kingranch's Avatar
t-stat could be stuck closed or partially. i would start with a t-stat thats damn hot
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #3 of 11 Old 05-30-2011, 05:44 PM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
Actually, no it isn't. The thermostat does not fully open until it is in the 220F range. Try the same thing without the tune, it will likely be cooler.
Please
You could save the life of a sick child
NYC F-350 is offline
post #4 of 11 Old 05-30-2011, 06:09 PM Thread Starter
so 220 is a normal operating temp? my 6.4L ran much cooler....it was almost always 192-196
barry1me is offline
post #5 of 11 Old 05-30-2011, 06:18 PM
NYC F-350's Avatar
Quoted: 54 Post(s)
No, I wouldn't call it a "normal operating temp."
Towing at 75MPH, tuned, with the AC blasting, and 80F outside are all factors.
The biggest factors are towing and tuned
Please
post #6 of 11 Old 05-30-2011, 06:22 PM
dazdillenger's Avatar
Feedback Score: 7 reviews
220 is a little on the high side, but not dangerous (seems like towing a heavy load would exacerbate the situation however)-Diesel's run more efficiently the hotter they get (to a point). Id change the t-stat and verify the clutch fan works.
dazdillenger is offline
post #7 of 11 Old 05-30-2011, 06:22 PM
That's Why I thought the t-stat was stuck. My 6.0 runs 190-195.
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
post #8 of 11 Old 05-30-2011, 06:32 PM Thread Starter
how do I verify if the clutch fan is working? What temp T stat should I get?
barry1me is offline
post #9 of 11 Old 05-30-2011, 07:03 PM
My fan comes on around 212-214* and the only t/stat to get is one from Ford because if something happen it will mess up in the stuck open pos. with that said your temps are fine the t/stat starts to open at 192.2 and is fully open at 219.2 no dig deal you are good.
O when the fan comes on it will sound like a jet plane.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS Expandable Pyro
AutoMeter Fuel Pressure Gauge
Updated Fuel Reg. Kit 3C3Z-9T517-AG
Amsoil By-Pass(Amsoil 5w40)
Delo ELC Coolant
Coolant Filtration System
pulling a 14,000 lb Alpenlite 5er
97 F350 4x4 PSD CC LB
PacBrake&ATS converter lockup
3" dp 4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A piller EGT,Boost,Trans
2 stroker is offline
post #10 of 11 Old 05-30-2011, 07:17 PM Thread Starter
2 stroker
I dont recall hearing the fan but i know it was on cuz when I opened the hood I could feel the air rushing back on the engine.
barry1me is offline
