6.0 engine replacement cab on - Ford Powerstroke Diesel Forum
Old 05-30-2011, 01:10 PM
just replaced a 6.0 in a 05 f550 4x4 with the cab on dont let these guys scare you took 23 hrs start to finish wasnt bad at all. you have to remove the turbo and y pipes to get it out but you can put it back with the turbo pipes and wiring harness installed. Lining up the converter studs was a little bit of a pain but a 1in hole drilled the bottom of the bell housing made it easy to turn the converter and line them up. I believe if it hadnt had a winch on it i could have done it in 20hrs. anyway dont fret it ant bad.ive done lots worse things
Old 05-30-2011, 01:19 PM
Good to hear. Have and pics?
Old 05-30-2011, 01:31 PM
no sorry guys no pics i had read so much crap about how hard it was just wanted to get it done i didnt even think about takin pics
