ECT seems kind of low. - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-30-2011, 08:19 AM Thread Starter
My ECT according to my SGII, won't go over 190, at least not for very long. At 65mph steady cruising, I can see it rise to 190, then the tstat opens, and it will drop to 188-186 and stay in that range. It will slowly work its way back up to 190, but drop back down.
This is a new tstat that went in after the coolant flush/change about 3 weeks ago. The tstat came from Tousley's, along with my blue spring and banjo bolts.
Just to throw this in, the EOT tracks the ECT, about 8-10 delta, so not worried about that side at this time.
Should I consider getting one of those radiator bibs to keep the temps up?
If I work it a bit, steep climb, etc., the ECT will rise up above 190.
Thanks
'06, XLT, F350 FX4, Auto, Ext. Cab Short bed
Diamond Eye Turbo-back 4" exhaust.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
beemerbiker5 is offline
post #2 of 7 Old 05-30-2011, 08:47 AM
FourFun's Avatar
Outside temp? My ECT stays close to 190 as well but if EOT rises then ECT follows. Doesn't sound out of the normal if ambient temps aren't real hot and your EOT doesn't run away from you ECT temps....
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
FourFun is offline
post #3 of 7 Old 05-30-2011, 09:09 AM Thread Starter
Outside temps were around 45-50F. The temps rose and fell together.(ECT-EOT)
With all the chatter about ECT needing to be over 190, just a bit concerned that my new tstat is bad.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #4 of 7 Old 05-30-2011, 09:39 AM
astroinhouston's Avatar
I am in Dallas and during the winter (that temp range you mentioned) my EOT would be in the 195 range while my ECT would be in the 188 range. Now that it is summer and 100* outside, mine are up to 210 on the EOT and 203 for ECT.
These temps are after an oil cooler rebuild in Sept. and coolant flush in Jan.
astroinhouston is offline
post #5 of 7 Old 05-30-2011, 09:46 AM Thread Starter
So, I am guessing don't worry, right? Just normal due to outside temps. I can live with that, just wanted to make sure.
CC Mod
Zoodad Mod
ELC swap
Coolant filter
Blue Spring upgrade
post #6 of 7 Old 05-30-2011, 10:11 AM
dazdillenger's Avatar
Feedback Score: 7 reviews
those temps are fairly close to normal given the ambient temp.
dazdillenger is offline
post #7 of 7 Old 05-30-2011, 10:24 AM
at0075's Avatar
My ect run usually from 184 to 192 I've seen it go all the way to 200.
I've been told 186-190 is normal. Wonder if I need a new t stat
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
