Head stud installed?
First time poster. Just bought a 2005 6.0 to pull my Regulator Boat. The truck has the egr delete. This is a long shot but i was wondering if there was a way to tell if he head studs were replaced and the oil cooler. Thanks
You'll be able to see if it has studs vs. bolts if you look at the corner of the head above the exhaust manifold. If you see a nut on a stud then you have studs, if you see a bolt head the it has the factory style bolts. There's really now way of knowing for sure with the oil cooler since you can't see it. Unless it has a remote mount cooler in front of the a/c condenser.
you can have an OASIS run against ur VIN which should show u maintenance done at the dealer. shot in the dark at least
