Looking at a 6L, need advise - Ford Powerstroke Diesel Forum
Old 05-25-2011, 07:53 PM
Hey all,
I own a 95 PSD so I am pretty up to date on the 7.3's.
I am looking at a 06 King Ranch w 6in Lift, 315's and 168kms. Ford installed a new engine @ 159Kms. Origional owner, all service records. Truck is a friend of a friends in Alberta Canada(Non Oil Field Truck). Price $20,000.00 CDN.
Is this a good price? I have seen local BC trucks of the same year, color, interior, kms, listed for aroun $34,000.00.
If I do purchase it, what should I do to make the 6.0L a solid engine. EGR Delete? Oil Cooler upgrade?
Could you please advise me if this is a good deal, and what needs to be done to the engine.
Thanks,
Ian
Old 05-25-2011, 08:12 PM
Originally Posted by ianjadkins View Post
Hey all,
Thanks,
Ian
New motor and all paper work and 20K not bad what is the total miles the best thing to do is get this ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool plug it in and take it for a spin get it up to temp the check the EOT-ECT max difference is 15* i think 10* the coolers are starting to get plugged this will tell you alot about the motor. If you get it coolant filter, gauges, fuel pressure gauge, coolant flush, and the list go on.
2 stroker
Old 05-25-2011, 08:45 PM
I am a Alberta guy as well, 20k seems pretty good for the year. I have seen some around the 24-26k mark but have no add ons. 2 Stroker gave great advice he knows way more than me about the 6.0l. Before buying you need to know how much diff there is in EOT and ECT.
To do list:
EGR Delete and rebuild oil cooler
Something to monitor engine vitals
Upgraded Fuel Pressure Spring Kit
Banjo Bolts
Coolant flush, switch to ELC, add a coolant filter
Studs when they blow if they do!!
Turbo drain hose
STC fitting
Dummy plugs
CCV
Syn Engine Oil (5w40)
OEM Oil and Fuel Filters only!!
There may be more, I am still learning. But I like my 6.0L, I will fix what ford didn't and move on. From all of my research it takes some $ to get these truck up too snuff, but then your good to go.
Old 05-26-2011, 06:10 PM
Thats a long to do list!
Old 05-26-2011, 08:27 PM
It is but only a few thing are major.
EGR Delete and rebuild oil cooler - SHOULD DO ($300.00)
Something to monitor engine vitals - MUST DO ($300.00 AND up)
Upgraded Fuel Pressure Spring Kit - IF FUEL PSI IS LOW ($100.00)
Banjo Bolts - PEACE OF MIND UPGRADE ($20.00)
Coolant flush, switch to ELC, add a coolant filter - MUST DO ($100.00)
Turbo drain hose - OPTIONAL ($? cheap I think)
STC fitting - OPTIONAL, if replacing oil cooler great thing to do also ($? cheap I think)
Dummy plugs - OPTIONAL ($? cheap I think)
CCV - OPTIONAL ($300.00)
The prices are ball park!! Also 1 more thing, if fuel PSI is a issue you may want to get your FICM cheacked.
