Head gasket Dow size. - Ford Powerstroke Diesel Forum
post #1 of 6 Old 05-25-2011, 12:43 PM Thread Starter
Sesco4's Avatar
I talk to the parts guy at the ford dealer today about head gaskets. He said that I needed to pull the heads and measure the Dow to make sure I get the right gasket. I though that trucks built before a certain date were 18mm and after that date are 20mm. My truck is an 05 and I thought I needed the 18's. Could someone point me in the right direction on this issue.
Thanks
2005 F250 CCSB 4X4
PHP Atlas 40 FICM Tune
PHP ECM/TCM Rollback
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Newton Lifts 2.5" leveling kit
Sesco4 is offline
post #2 of 6 Old 05-25-2011, 01:09 PM
rem1981's Avatar
They say that in case you had your engine replaced and now have different dowel sizes than it should have originally. But, they should be able to go off of the head casting number alone. I had to do that when I ordered my heads so the shop could send the correct sized dowel heads.
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #3 of 6 Old 05-25-2011, 01:11 PM
The Silent Service
colo_dually's Avatar
Quoted: 15 Post(s)
The 20MM Dowel Headgaskets were on Jan 2006 trucks and later. You should need 18's, unless you did an engine swap or something crazy like that.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 6 Old 05-25-2011, 01:59 PM
Quoted: 5 Post(s)
In my experience the 2005 should have 18mm dowels
a2elvis is offline
post #5 of 6 Old 05-25-2011, 06:27 PM Thread Starter
Sesco4's Avatar
Thanks for all the replys I was thinking they should be 18's but just wanted to make sure.
2005 F250 CCSB 4X4
Old ECM VXCF9N4
New VXCF4N3
Old TCM TQCI1NA
New TQCI0N3
Zoodad Mod
Delo ELC Coolant
Rotella T6 w/Rev-X
Fumoto Valve F-111
2009 Rear Bumper
Sesco4 is offline
post #6 of 6 Old 05-25-2011, 06:43 PM
police251's Avatar
18's is what you need I have the same truck......
police251 is offline
