need oil help pls
ok guys what is the best oil to run in a 6.0? is ther any problem with that rotella t5 10w-30
5w40 Syn!! Rotella, Amsoil, Mobile 1, are just a few. 5w40 is what most of the guys will tell you too run, you want a quality brand full Syn. I am running a 10w40 Syn (Petro Canada) currently but will most likely switch.
Mobil is good. I use it. Keep the oil changes under 7,000 miles.
The dealer that I go to uses Mobil Delvac 5w-40 full synthetic, have not checked to see what is different then regular Mobil 1. Just make sure whatever you use it has a CJ-4 rating.
I'm also running Mobil Delvac 1 5w40 full syn. It is approved by Ford, and sold at the dealerships.
Really, any full syn 5w40 will make your truck happy. |
Redline synthetic, Rotella T6,
167 for 4 gallons delivered for redline It is ester based, some of the best oil in the world. Rotella T6 is a blend of group III (refined dyno oil) and PAO. Quote:
If you want to run regular oil, Delo LE 15w40 An oil change will cost you 45 bucks and you can change it every 3000-4000 miles. Very good stuff. Cheap at Walmart. |
ok guys thanks for all the help i will probably stay with rotella? would a 10w-30 make the truck run a little warmer?
Rotella does seem to be a favorite around here ( I run T6) but like said above 5-40 syn will do ya right. Check out the thread on oil in my sig
Haha. See that, we can agree on something! |
Good morning Mitch,
That is good to hear, I did not know you were a fan of redline. It is great, just not readily available if you don't order it ahead of time. I think our friend sanbar did not realize how expensive the "best" can get lol. What he really meant was "the best cheap oil". Love to see the sticker shock reaction. ![]() sanbar, if you aren't towing T5 will be fine. T6 if you run the truck hard or tow. If you change your mind, there is even cheaper! ![]() T5 will run you about 80 bucks for 4 gallons. Delo 15w40 will run about 48 or less. |
