Anyone Use Fleet Charge Coolant - Ford Powerstroke Diesel Forum
Old 05-24-2011, 02:26 PM
Anybody used fleet charge coolant before? Thinking about letting a local service center that works on diesels do my flush and he says they use this stuff. Didn't know if it was EC 1 rated? Info from the website below - Thanks
6. Is Fleet Charge an "extended life" coolant?
The term "long life" usually is associated with coolants that contain carboxylic acid inhibitors. Therefore, we have described Fleet Charge as a Fill-For-Life technology.
back to top
7. What is meant by the term Fill-For-Life technology?
The Fill-for-Life alternative provides for easy, low cost monitoring of the coolant inhibitor and freeze protection levels. Fill-For-Life is an extended service maintenance program developed by Fleet Charge and Penray researchers. It is very simple. Users simply install a Penray Need-Release filter on an engine coolant system (up to 30 gallons). Every 18 months the filter is replaced. This practice eliminates scheduled coolant changes.
Old 02-25-2012, 09:22 AM
Old thread but I have the same question. Oriellys carries this coolant and I was wondering if it was safe for the 6.0. Thanks
Old 02-25-2012, 01:12 PM
No, it is not a Cat EC-1 rated ELC coolant. This is made clear by in 7. where it states it uses a Need-Release filter. The Cat EC-1 spec does not require the use of SCA/DCA additives.
Old 02-25-2012, 01:50 PM
Thanks for the reply.
Old 02-25-2012, 03:58 PM
But this will work
NAPA AUTO PARTS
2 stroker
Old 02-25-2012, 06:32 PM
Thank You.
Old 02-25-2012, 06:50 PM
Originally Posted by 2 stroker View Post
But this will work
NAPA AUTO PARTS
2 stroker
I'm being lazy, but how many gallons would one need to do a complete flush? I believe it is 4 but was not sure.
Thanks,
Bri
Old 02-25-2012, 09:29 PM
Thanks,
Bri
I used 1/2 gallon Restore, 1/2 gallon Restore+, 48 gallons Distilled water, New Ford t/stat, 1/4 tank of fuel, 3 1/2 gallons of Delo ELC coolant.
Took 12.5hrs to do the flush but it is clean.
2 stroker
Old 09-15-2012, 08:18 AM
2 stroker:
Were you having eoc/ect delta issues? And did the thorough flushing you performed help any if you had any eoc/ect delta issues?
Thanks!
