Scan Gauge II Help with code - Ford Powerstroke Diesel Forum
post #1 of 12 Old 05-24-2011, 09:03 AM Thread Starter
police251's Avatar
I have a scanguage II and the fuel code is the only on not working. It installed in a 2005 6.0 PSD does this truck not give this info. I really want to get a code that works my fuel gauge for the truck is going out and dont want to be standing on the side of the road..... Thank you for your input and helping me out...
This is the only code I have found......
Fuel Level
TXD: 007E02216C1
RXF: 0462451606C1
RXD: 3010
MTH: 000101480000
NAM: FL
im I doing something wrong with the set up?????
police251 is offline
post #2 of 12 Old 05-24-2011, 06:27 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I used to have that one in my SGII. Just was testing to see how it worked. Worked fine in mine. Not sure why it isn't working in yours.
I believe I used the one they list on the SGII Xgauge website. But not for sure, I deleted it for room for the other 30+ gauges in there.
Sorry.
Oops, I just re-looked at your codes you posted Check the first set for TXD, you have 2 "0's" at the beginning.
07E02216C1 0462451606C1 3010 000101480000
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #3 of 12 Old 05-24-2011, 06:40 PM
FourFun's Avatar
Yea double check that you entered the numbers correctly. Its easy to mess up, and not many seem to have problems with the fuel gauge so more than likely its a keystoke error. Let us know!
04 6.0l Excursion
4x4
6" Lift, 35' BFG's, Powermax
AFE Intake, CFM+
Swamps 58v ficm, ARP, EGR delete
Sct x3 w/ID,DJ,GH tunes, Autometer/Isspro
4"MBRP SS exhaust cat/muffler delete
6.4 banjos, FPR spring upgrade
Shell Ultra ELC, Coolant filter, CCV mod, Zoodad Mod
07' Harley headlights, 08' Tow mirros
Hellwig swaybar, Billstein 5100's
FourFun is offline
post #4 of 12 Old 05-24-2011, 06:42 PM Thread Starter
police251's Avatar
I just put it in and a no go... I cant figure out why this is not working... I wounder if the way I set it up has anything to do with it not reading...
post #5 of 12 Old 05-24-2011, 06:50 PM
FourFun's Avatar
You've entered in other codes correct? I know when i first started messing with mine it can be tedious at first with all the numbers. Just double/triple check your numbers are right without extra spaces, save it, and check it to see if it works. The code you posted originally is the code i have, minus the extra "0" you have in your txd.
04 6.0l Excursion
4x4
AFE Intake, CFM+
FourFun is offline
post #6 of 12 Old 05-24-2011, 06:52 PM
DesertSmoker's Avatar
Yes if your fuel sending unit is out the Scanguge will read the same as your gauge on the dash. Is your fuel gauge below the red E line?
For Sale--2003 F-250 CC 4x4 SB 6.0
Custom 03 Turbo, WPE Intake,
HD 97 Fan Clutch, MBRP Y Pipe,
Scangauge II Rancho 9000XL,
BFG 285/75 R16, Galaxy 94HP
DesertSmoker is offline
post #7 of 12 Old 05-24-2011, 07:12 PM Thread Starter
police251's Avatar
No my fuel level is at a full tank .... How many codes can I have saved on the unit at one time... Someone told me ten plus the stock ones on the unit... if this is the case I have way to many in stored... It shows up but is blank and dose not show a precent of fuel left....
post #8 of 12 Old 05-24-2011, 07:17 PM
Quoted: 4 Post(s)
I have about 20 Xgauges on mine. No problems with those plus the stock gauges that came with it.
Try this for giggles.
Un plug the Scangauge. Let sit a minute or so. then plug back in. Let it scan and see if that clears things up.
post #9 of 12 Old 05-24-2011, 08:02 PM Thread Starter
police251's Avatar
i will check it out tomorrow and let you all know if it works I was going to try to delete the current code and redo it... thanks for all your help
post #10 of 12 Old 05-25-2011, 06:16 AM
Quoted: 5 Post(s)
The ScanGuage guys are happy to help give them a call I bet they can get it figured out over the phone 888-433-5664
a2elvis is offline
