Doing all updates, need P#'s please
Hey guys, I live an hour and a half from my Ford dealer and the last time I was in town I stopped in and asked the parts guys about the Blue fuel pressure spring, the turbo oil drain and feed lines and the SCT fitting. They just looked at me like deer in headlights. None of the parts guys know what I was talking about at all and just said they didnt even exist. I wanted to throttle these guys, didnt even try to help me out. Can someone here please hook me up with the part #'s of these please...Got the FPR kit number thanks to a recent post on here, but the turbo drain and feed tube #'s would be awesome and so on. Thanks again guys.
I have been trying to keep a log of part numbers which I see frequently or that interest me.
6.0L Common Parts List Motorcraft International Fuel System primary fuel filter cap and oil filter cap 3C3Z-6766-A 1813354C3 Secondary fuel filter cap 3C3Z-9G270-AA 1843057C92 HFCM Manifold (Cover) 6C3Z-9B249-A Fuel Pump (HFCM) Kit Injector and Glow Plug System FICM Part #'s: 4C3Z-12B599-AARM 5010121R94 04 8 o-ring sets for injectors 3C3Z-9229-AA 1843682c91 Old (long) glow plug (03-04) 3C3Z-12A342-AA 1836600C1 New (short) glow plug (04.25 up) 4C3Z-12A342-AA 1843286C2 Injector (2003) 3C3Z-9E527-AE Turbo chra: center housing and rotating assembly: 03 center housing 3C3Z-9G489-BARM 03-04 center housing - Bolted w/o clamp plate 4C3Z-9G489-AARM 05-07 center housing 5C3z-9G489-aarm Unison Ring 3C3Z-6C885-A Updated oil drain tube 6C3z-9T515-a 1876071C91 06 oil feed tube 3C3Z-9T516-A 1845287C96 04 Turbo gasket kit 3C3Z-9T514-AD 1840053C96 03-07 Trbo Hrdwre kit w/ 3M pads 4C4Z-9V424-AA 1870713C91 EGR System 04-07 EGR Cooler 4C3Z-9P456-AF (after 9/23/2009) High Pressure Oil 2003 / 2004 HPOP 4C3Z-9A543-AARM 5010106R93 2005 / 2006 / 2007 HPOP 5C4Z-9A543-B 5010119R92 Dummy rail plugs: W302908 Kit for dummy plugs and stand pipes: 6E7Z-9A332-B STC Kit 4C3Z-9B246-F 1879930c91 IPR (05-07) # 5C3Z-9C968-CA 1846057C1 03 ICP - 04 (pre 9/23/03) 3C3Z-9F838-EA 1845274C92 04 (post 9/23/03) 05 up ICP ($150) 4C3Z-9F838-AA 1845428C92 ICP pigtail 5C3Z-12224-A 1850712C91 Upgraded fuel pressure regulator kit 3C3Z-9T517-AG Updated HPOP cover part numbers 6/25/10: 03 3C3Z-9G805-AA Updated HPOP cover part numbers 6/25/10: 04 4C3Z-9G805-AA Updated HPOP cover part numbers 6/25/10: 05,06.07 5C3Z-9G805-B HPOP Filter Screen 3C3Z-6C683-AB 1838526C2 HPOP 05 and up # 5C4Z9A543B HPOP, 03, 04 # 4C3Z9A543AARM Low Pressure Oil Oil Cooler Kit - Replaceable Core 3C3Z-6A642-CA Oil Cooler Kit - Entire cooler, Housing and all 3C3Z-6A642-AA Coolant and emissions system New degas (coolant overflow) bottlecap 9C3Z-8101-A Thermostat Housing O-ring 3C3Z-8255-AA PMP ASY-WTR - 2002.5 to 7/18/2004 3C3Z-8501-ABRM 5010100R92 PMP ASY-WTR - 7/18/2004 and up 4C3Z-8501-ABRM 5010118R91 Radiator 4C3Z-8009-BA Engine 04 head gasket kit - gasket only 20 mm dowell?? 18403463c6 Other Exhaust manifold gasket 5C4Z 9448A Fel Pro MS96833 Vacuum Reservoir 4C3Z-9E453-AA Carrier bearing F81Z-4800-FA |
Call Tousley Ford, 800-328-9552 and have that stuff drop shipped to your door cheaper than you buying through that dealer. Just have the last 8 of your VIN ready and they will find everything you could want. There are a few guys there that REALLY know this engine |
What years was the carrier bearing updated?
Not sure, I need one (haven't done it yet) so I looked up the PN and found that one. Not sure if its updated or not?
Thank you very much guys, that is most appreciated. Its guys like you who really make the difference!! This helps me out immensely, gonna call the other Ford dealer in town and order the parts I need....BTW that parts list is so good, you should make that a Sticky, could help a lot of guys out instead of having to ask the forum. Thanks again boys
