6.0 wiring diagram? Need help! - Ford Powerstroke Diesel Forum
Old 05-23-2011, 01:14 PM
KING of BLING!
I am trying to find out a full wiring diagram for an 05 6.0. I need to know what color wires go to the starter relay and fuel pump fuse. I bought a haynes manual but no such luck. I tried searching everywhere on the net too.
Old 05-23-2011, 04:50 PM
information regurgitator
F250 or 350?
Manual trans or auto trans?
w or w/o dual alternators?
I don't know if those make a difference, but there are different wiring diagrams for each of those.
Old 05-23-2011, 04:57 PM
KING of BLING!
NYC, sorry about that. Single alternator f250. Automatic.
Old 05-23-2011, 05:12 PM
Coming off of fuse 31 (15amp) in the central junction box (left side dash) wht/pnk wire goes to the starter relay (central junction box, behind lower left dash)
Dark green wire comes from ignition switch to the other side of fuse 31
Starter relay pin #85 is the connecting point for the wht/pink wire from above.
Starter relay pin #86 has a pink wire that goes to the starter relay control in the PCM
starter relay pin#87 has a yellow/light blue wire that goes to the starter motor
starter relay pin #30 has a red wire that goes to the battery junction box (left rear of engine bay)
the other wire on the starter is red and comes off of the battery
Fuel pump fuse, next post
EDIT: I want to be forthright that this is taken from a manual I have, but it is from the 06 year. I am not 100% certain that it was unchanged between 05 and 06 years.
Old 05-23-2011, 05:31 PM
Feedback Score: 7 reviews
I have alldata-just let me know which diagrams you need, Ill post them.
Old 05-23-2011, 05:36 PM
Fuel pump fuse: fuse #40, 20 amp
From the FICM: Fuel delivery circuit light green/yellow wire goes to PCM (drawing A)
From the PCM: to Fuel pump relay - light blue/orange (pin#5)
From fuel pump relay to the inertia fuel shut off switch is dark blue/yellow
from the inertia switch to the fuel pump is pink/black
other side of fuel pump is a black ground wire
Hope this helps, good luck
Old 05-23-2011, 08:11 PM
KING of BLING!
Thank y'all for all the help. I need this info for an alarm installation. I really appreciate it.
