SeaFoam Opinions - Ford Powerstroke Diesel Forum
Old 05-22-2011, 12:37 PM
SeaFoam Opinions
Yay or nay?
Old 05-22-2011, 12:50 PM
information regurgitator
NAY
That stuff does not belong anywhere near the 6.0
Old 05-22-2011, 05:29 PM
Nevermind, found my answer.
Old 05-22-2011, 05:52 PM
I think i would only use that stuff in my gasser vehicles, and my boat! but im not real big on addatives though. im not even sure sta-bil is all its cracked up to be
Old 05-23-2011, 03:44 AM
I've used in gassers for years, esp. my boats. Dunno bout a diesel though.
Old 05-23-2011, 06:34 AM
Originally Posted by NYC F-350 View Post
NAY
Was it the post before yours? lol
Old 05-23-2011, 06:40 AM
Nah. Didn't come up in the search que the first time I tried.
But he is right.
Old 05-23-2011, 06:48 AM
Seafoam is a useful product, it works well on a lot of different stuff!
But it is way expensive for what it is...
It is:
50% mineral oil
20% rubbing alcohol
30% benzine
I've used it to free up rings on outboards and it restored compression to factory specs on a 25 year old motor. I think most people have used it through the brake booster on a car or two.
Not sure I'd put much in the crankcase of the Powerstroke because of the HEUI system. Not really worth putting it in the fuel either. I'd use a good diesel additive.
Old 05-24-2011, 02:46 AM
If your intention was to use SeaFoam as an engine flush, don't waste your money.
Use GUNK "motor flush".
If you've never used it before, pour in two bottles and let your engine run for 10 minutes @1500rpm or less with no load on engine (no driving, turn off AC).
It will dissolve junk and it will be mixed in with the oil, so drain it right away.
Monitor your oil pressure while you are running it with Motor Flush.
If you want to take an extra step, after draining refill with some walmart 10w30 after running that for a 10 minutes drain it, replace oil filter, fill with good diesel oil.
