Go back to stock before Edge CS install? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-19-2011, 09:11 PM Thread Starter
I understand if it is just covering their rear when they say in the Edge CS user guide you must remove the program and programmer from the truck before installing the CS, just in case you screw something up. But since it is only a monitoring device, with the ability to change some things, is it imperative to set the SCT X3 back to stock? I had it reset so there are no unlocks used and would prefer to keep it that way if possible. Besides, after putting the CS in, I would be putting the SCT X3 right back in, with an IDP tune...
Put it back to stock or not?
2005 F350 SRW, Crew cab short bed Lariat FX4. 85k. BPD HD oil cooler setup, BPD EGR cooler, Scanguage monitor.
2004 Excursion 6.0 - Lots of mods! SOLD!!!
Squid4life is offline
post #2 of 8 Old 05-19-2011, 09:52 PM
teamcasslake's Avatar
Send a message via AIM to teamcasslake
i just installed my cts without putting back to stock.
2005 F-350 Crew Cab long Bed-
100% Nozzles(70hp supposedly)
SCT X3-DP Tuner Tunes, 60TOW,80ECON,120HP(DD)
Magnaflow 4" straight piped
AFE stage 2
River City EGR delete
GoodYear duratracs
Pioneer AVH-P4300DVD
Kicker ZX350.4
Rockford Punch 6x8"s
Kicker ZX500.1
2 Rockford Punch 10"s
teamcasslake is offline
post #3 of 8 Old 05-19-2011, 11:18 PM
Quoted: 2 Post(s)
Like you said its just a monitering device, i installed mine and didnt return my truck to stock-no issues.
2006 F350
6.4 banjos
FP spring
Insight CTS
IDP/Looney SCT X3
Studded
Durastroked
S&B,CCV
FICM Repair/PHP 40hp
2008 F250 FX4
DPF-R +
06DZL is offline
post #4 of 8 Old 05-20-2011, 04:07 AM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
You have to take the cable off the OBII port anyway to reflash with the SCT. I think its EDGE covering themselves. I've had no issues with my Insight, and it was put on after the tunes.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 8 Old 05-20-2011, 04:34 AM
Mike Hickman's Avatar
It's good to refresh the tune anyways you notice the difference .
TRUCK WAS STOLEN NOW IS SOLD 2006 Lariat FX4 F-350
7" BDS Lift
SCT Xcal3 Tuned By Truck Source Diesel TSD with SPD !
Triple pod Auto Meters
4" MBRP Exhaust
Straight piped Turbo back
Zoodad Mod
325/65/18 13.50's MTZ
18x10 Mickey Thompson Bead Locks
A1 H11 Studs Head Bolts/Studded
EGR Deleted
Harley HeadLights
S&B Intake
Mike Hickman is offline
post #6 of 8 Old 05-20-2011, 06:19 AM
PGreenSVT's Avatar
Feedback Score: 3 reviews
That's because of the Dmax. You can ignore it.
Got questions about your 6.0?
Still runninng Ford Gold Coolant?
PGreenSVT is offline
post #7 of 8 Old 05-20-2011, 06:38 AM Thread Starter
Thanks guys, much appreciated. Was anxious to get it on and see what my delta was but it won't read the vin. It wants me to use to software to enter it. Ugh... was really curious about the delta... Oh we'll hopefully after work I can get time to do it. Thanks again.
post #8 of 8 Old 05-20-2011, 07:06 AM Thread Starter
You mean set it back to stock, then put it back on to whatever tune you were running? I assume this is because when you first install the tune, it runs great, but after time and the trucks' computer "learning" it gets a little lazy? If that is what you mean, that makes sense. Always learning here!
