just got truck already a problem help...rough idle
ok got this truck two weeks ago love it..
recently..after i let it sit a while..i will have no power and rough idle..once it warms up..all power is there... it will sound weird..and smoke a little..and sometimes it wont even have enough power to get out of drive way..and it will shift weird... 04 ..never been programmed (dealer said) has latest flashes from ford..egr delete..dealer said they changed oil and fuel filters and two new batteries...so whats the deal?? injectors?? only started doin this recently... once warm runs like a champ..help me pleassse |
Sounds like a FICM issue. Fuel injection control module, search for FICM and you'll find gobs of information. Also, search swamps diesel for a write up and testing your FICM or www.circuitboardmedics.com.
Good luck. If bad FICM, don't buy from Ford, use one of the places that fix them vs buying factory new. Cheers. |
great thanks alot..ill read up on it
FICM or injector stiction. Check the voltage on the FICM when cranking over and when running (test when truck is cold) If the voltage drops below 46v then the FICM is toast. Send it to Swamps Diesel and get a 58v FICM. If the FICM is good add 2 bottles of Rev-X to the oil. REV-X Oil Additive | Diesel Fuel Additive | High Performance Oil That should clear up any stiction issues.
Be anal about maintenance. Oil changes at 5k with 5w40 synthetic and use Motorcraft or Racor filters. Racor makes the Motorcraft filters and are cheaper. Fuel filters every other oil change. Home - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks |
ok im gonna buy rev x today...hopefully will help...but i havent checked the ficm yet...so ill keep updated.. thanks!
