Front axle ABS sensor replacement....how hard to install? - Ford Powerstroke Diesel Forum
Old 05-18-2011, 10:16 AM
My ABS light came on in my 06 F250. I had it scanned at advanced auto and they said its the passengerside wheel sensor is bad. Anyone replace one yet to see how hard they are to do?
Old 05-18-2011, 10:17 AM
I have the same light on, subscribing for more info
Old 05-18-2011, 12:08 PM
information regurgitator
Just stick your head in the wheel well and take a look. Allen head on the hub, one on the knuckle, and maybe 2 other bolts that hold the wire from getting caught in stuff. Easy beans.
Old 05-21-2011, 08:34 PM
it looks to me like its behind the rotor....Are the rotors easy to change or do you have to pull the hub off also?
Old 05-22-2011, 04:59 AM
Yea, you'll have to pull off the wheel, caliber, and rotor assemblies. There's a 6mm hex head that connects it to the hub, 8mm bolt that holds it in place behind the dust shield, then there's a plastic clip on the frame that you can use a flat head screwdriver to undo. Also use a flat head screwdriver to disconnect from the main harness. Probably a 30 min job, ez stuff
Old 05-22-2011, 08:30 AM
Thanks man!!!
