egr plugged - Ford Powerstroke Diesel Forum
Old 05-16-2011, 12:48 PM
egr plugged
I have an 06 with 60k in an f550 it had a bad miss so I hooked it to the scanner and it came up with several erg codes and a cylinder 1 missfire. Pulled the egr and it was all scummy and plugged up so cleaned it all out and reinstalled. The miss is a lot better but still there more in the low end.. truck is bone stock. Thoughts comments suggestions please?
Also since egr was plugged what else should I check for being plugged?
Old 05-16-2011, 02:40 PM
information regurgitator
Anything/everything that connects to the intake. Such as check your MAP sensor hose and the nipple.
Maybe the EBP sensor, drivers side exhaust manifold, stainless steel tube coming off the front of it and going towards the back. Remove sensor, blow the crud off it and then down into the tube.
Old 05-16-2011, 08:27 PM
thank ya
what is involved in an egr delete kit?
also decided to pull the number 1 injector tomorrow morning and see whats going on with that
Old 05-16-2011, 08:32 PM
egr cooler
hey ford guys sorry to interupt but im new here and was wondering were to go to find info on about removeing egr cooler?
Old 05-16-2011, 08:52 PM
no worries im wondering myself im new to the 6.0
Old 05-16-2011, 09:10 PM
Angry
yeah I just purchased an egr delete kit im installing it now but cant figure out how to remove the egr cooler
Old 05-17-2011, 05:22 AM
Whitejohn try throwing a couple of bottles of Rev-X in before pulling the injector. If it is sticking that will most likely clear it up. Also synthetic oil keeps that from happening.
To remove the egr cooler, remove the turbo, remove the oil/fuel filter cans, remove the intake. Replace the passenger side up pipe, reassemble in reverse.
Old 05-17-2011, 10:40 AM
Yea I'm down to the egr cooler and I took off all the top bolts it still won't budge any ideas or were the rest of the bolts are located then wats after that????
Old 05-17-2011, 10:43 AM
You should remove the intake and clean it out. That crud is all over the inside effecting flow and it is going into the cylinders.
Old 05-17-2011, 12:58 PM
It is only held on by the v-band clamp on the rear and 2 bolts through the manifold in the front, and the hose connection.
