switched power source - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-16-2011, 11:22 AM Thread Starter
at0075's Avatar
Installing my gauges and thought I had a switched source. About 3 inches u obd port. White wire with blue stripe with black tape end. Not working. Anyone else have any ideas or thoughts. Thanks
2004 f350 6.0, 6spd, studs, 175/stock warrens, deleted, blue spring, 6.4 banjos, strait 4 in exhaust, zoo dad mod, 35s, 3.5 in lift,
at0075 is offline
post #2 of 5 Old 05-16-2011, 03:30 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Open the fuse box. Left hand side of it. See those prongs (spade) sticking out? One of those is actually switched with the ignition. Use a test light to find out which one it is. The standard crimp on spade connector fits. Strongly suggest an inline fuse.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 5 Old 05-16-2011, 03:59 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I think the wire you found is for the "high Idle" mod.
You will see it in this "high Idle" mod link:
High Idle Mod
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #4 of 5 Old 05-16-2011, 05:14 PM
mah77's Avatar
Here ya go:
Switched Hot FYI.
06 F250 FX4 Lariat, 35" Nitto Terra Grapplers, 6" Lift Leveled w/Bilsteins, 4" MBRP TB Exhaust w/Cat Delete, Edge Insight w/EGT Probe & Dash Pod, SCT X3 w/SRL Tune From Matt @ Gearhead, Powerslot Rotors, Hawk Pads, Upgraded Oil Cooler Screen, Upgraded Turbo Drain Tube, Upgraded STC Fitting, Upgraded FPR Spring, CAT ELC Coolant, ARP Head Studs, Opti-Lube XPD, Coolant Filter, 45K Miles
mah77 is offline
post #5 of 5 Old 05-16-2011, 08:50 PM Thread Starter
at0075's Avatar
Thanks for the input. I have them temporarily hooked to a switch with a fuse running from thebattery. I will dig into it more tmrw. I'll be glad when I am done climbing under dash lol
at0075 is offline
