White smoke at start up and acceleration - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-15-2011, 08:41 PM Thread Starter
Quoted: 2 Post(s)
Okay, I know I've seen something on here about this before. Relatively new to the site. 2004 6.0 108K miles, 4" lift with 35's. I have had the egr valve replaced 4 times now, and I believe that this is what may be going on again. I went out and started my truck this morning and it blew a large ploom of white smoke. As it was warming up, it continued with the white smoke. When I went to get in the truck, it seemed to have stopped, however when I was heading down the road, I noticed a consistant white smoke coming from my exhaust. So I had an edge programmer, until it got stolen. Another ?, would the shop (ford) have changed my programming when they changed out the egr, egr cooler, turbo boot, and oil cooler? I'm not even certain of that. Thanks in advance
9er4lf is offline
post #2 of 8 Old 05-15-2011, 08:58 PM
B4SouthernMiss22's Avatar
Headgasket possibly?
2001 F-250 7.3. Garrett GTP38R ball bearing turbo, MBRP 4" exaust, muffler delete mod, Bully Dog 6 pos. chip, Edge CTS, 4" suspention lift, and moto metal 20's w/ 35/12.50/20 nitto Trail Grapplers
B4SouthernMiss22 is offline
post #3 of 8 Old 05-15-2011, 09:20 PM
2003kingranch's Avatar
EGR COOLER
2012 King Ranch
22k deleted at 1k
5" FLO-PRO
S&B Intake
Sinister Egr Delete
MiniMax/ SPE Tunes
466/953 on 37's
6" 4 link
37's on 22's
Bags and compressor
RBP mudflaps
transfer tank tool box.
9" 2" poly boss v blade
Should have kept my 6.0.....
2003kingranch is offline
post #4 of 8 Old 05-15-2011, 10:30 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
What does it smell like?
Coolant smell=EGR cooler
Diesel smell= injector
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #5 of 8 Old 05-15-2011, 10:43 PM
rem1981's Avatar
White smoke is generally the result of coolant getting into the combustion chamber. How is your coolant level? Is there any milky look to your oil?
I dream of a better tomorrow, where chickens can cross the road and not be questioned about their motives.
rem1981 is offline
post #6 of 8 Old 05-16-2011, 04:21 AM
Agreed - do the smell test!
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 8 Old 05-31-2014, 08:42 PM
I also have a 2004 F250 4x4 6.0 with 159k. When purchased 2 months ago truck had ARP headstuds and a 5" turbo to tip exhaust. I bought SCT Livewire to keep track of my vitals (tunes are nice also) and an S&Bcold air intake. Notice coolant temp range from 184-190 and oil temp at 220-243 and got concerned. Truck did not smoke at all. I bought an oil cooler a complete egr delete kit and a coolant filtration kit and had a certified Ford diesel tech install everything as well as rebuild the Garrett turbo. 2 days after installing all this truck white smokes on acceleration. Haven't done smell test yet. What can it be?
JEBII is offline
post #8 of 8 Old 05-31-2014, 09:30 PM
JustinOOO9's Avatar
Quoted: 464 Post(s)
Garage
Pull the egr valve yourself and see if it's wet... If it is your egr cooler was starved of coolant because of a clogging or clogged oil cooler.
You need to monitor your engine oil temp and engine coolant temp when fully warmed up. Odds are the difference is more then 15 degrees. If you google balloon test for your coolant reservoir tank it will give you a good indicator on your head gaskets. Are you loosing any coolant?
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake.
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
