oasis anyone? - Ford Powerstroke Diesel Forum
Old 05-15-2011, 12:43 PM
oasis anyone?
04 6.0 250 1FTNW21P94EA05315
Old 05-15-2011, 01:59 PM
Powerstroke Techie
Feedback Score: 3 reviews
it's had the ICP changed and turbo drain tube orings changed for an oil leak concern. had the #8 injector replaced for contribution code and had the turbo cleaned for a stuck condition. the injector and turbo were done at around 170k miles, obviously the owner had some kind extended service plan
engine serial number is S6113503
rear axle is 3.73 limited slip
Old 05-15-2011, 03:18 PM
Can you see anything on mine. I've had it run before and was told it was blank or couldnt be ran. 05 ex 1FMSU45P65ED43315 thanks in advance.
Old 05-15-2011, 03:52 PM
Thank you Sinner6.0l I see you are from PA i grew up in Cannonsburg not far from you
Old 05-15-2011, 09:31 PM
vin#1FMSU45P65ED43315
IN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FMSU45P65ED43315 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-JUN-2005 10-FEB-2006 152460 USA 21 * * * * * * * 42668
AWS Claim Key: 8741577 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 02441 - * Name: BANKSTON FORD OF FRISCO, LTD, CO. Ph: 972-3355000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-OCT-2007 Doc #:504413C
Cust Comments: RECALL 05E16
Tech Comments: 42668 REPROGRAM PCM PER RECALL
AWS Claim Key: 8741578 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02441 - * Name: BANKSTON FORD OF FRISCO, LTD, CO. Ph: 972-3355000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:09-OCT-2007 Doc #:504413D
Cust Comments: RECALL 05B32
Tech Comments: 42668 ADD LABLE PER RECALL
1FMSU45P65ED43315 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-JUN-2005 10-FEB-2006 152460 USA 27 2E03 030402 4C3Z 9E527 BRM E29 42 59251
AWS Claim Key: 9723079 Trx Code: S07 Labor Hrs: 5.6
Dlr Cd-Sub Cd: 05078 - * Name: MEL HAMBELTON FORD, INC. Ph: 316-4623673 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2008 Doc #:12738601
Cust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON DEISEL WARR
Tech Comments: DIESEL EMISSIONS PART COVERAGE WARRANTY PERFORMANCE DIAGNOSIS PER GUIDE, P0675, P0263, DIAGNOSE GLOW PLUG CIRCUIT CONTROLLER INOP & #5 GLOW PLUS OPEN. REPLACE CONTROLLER & GLOW PLUS. REFLASH MODULES PER TSB 07 5 4. ROAD TEST, VEHICLE MISSES PERFORMED POWER BALANCE. CYLINDERS #1 & #3 MISSFIRE. PERFORM TSB 06 13 3 TEST FUEL PRESSURE 49PSI, REPLACED #1 & #3 INJECTORS.
1FMSU45P65ED43315 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-JUN-2005 10-FEB-2006 152460 USA 27 2E01 030008 3C3Z 9F838 EA L65 D8 59420
AWS Claim Key: 9710511 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05288 - * Name: KLINE MOTORS, INC. Ph: 620-2212040 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:18-APR-2008 Doc #:02595401
Tech Comments: ENGINE LEAKS SMOKE UNDER HOOD DYE TEST R AND R ICP SENSOR ADDED OIL VERIFIED
1FMSU45P65ED43315 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-JUN-2005 10-FEB-2006 152460 USA 33 2E01 030408 4C3Z 9B246 C D21 42 72556
AWS Claim Key: 10477252 Trx Code: E72 Labor Hrs: 6.7
Dlr Cd-Sub Cd: 05078 - * Name: MEL HAMBELTON FORD, INC. Ph: 316-4623673 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2008 Doc #:13924501
Cust Comments: CHECK DIED WHILE DRIVING, CRANK NO START VEHICLE TOWED TO OUR DEALER
Tech Comments: PERFORMED SERVICE PROCEDURE PER TSB 08 18 6 PERFORMED AIR TEST, REMOVED HIGH PRESSURE PUMP COVER FOUND STC FITTING BLOWN OFF REPLACE HIGH PRESSURE PUMP FITTING 081806C 1.8HR 081806D 4.9HR CAUSAL 9B246 CODE 42
1FMSU45P65ED43315 T/L1 F T/WD T/BD T/E A1 T/BE T/YB 24-JUN-2005 10-FEB-2006 152460 USA 33 1A02 030102 * 6051 * D42 42 73711
AWS Claim Key: 10493099 Trx Code: E72 Labor Hrs: 10.7
Dlr Cd-Sub Cd: 02441 - * Name: BANKSTON FORD OF FRISCO, LTD, CO. Ph: 972-3355000 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:16-OCT-2008 Doc #:527424A
Cust Comments: CHECK ENGINE LIGHT IS ON CUST STATES THAT VEH IS LOOSING COOLANT AND POWER CHECK OASIS HISTORY
Tech Comments: 73711 LIGHT ON LOW POWER 081103A 2.3,B 6.5,C 0.5,G 1.4 1070 CC42,6051,IDS DIAG DIESEL ENGIN DIAG PRESSURE TEST COOLING SYSTEM EGR COOLER FAILED PRESS TEST EGR VALVE STICKING ,COOLANT RESIVOR AND CAP FAILED PRESSS TEST REPLACE EGR COOLER,EGR VALVE,COOLANT RESIVOR,CAP.CLEAR CODES P0401,P0404,FOR EGR VALVE CONCERN REPROGRAM PCM,TCM,FICM RETEST ROAD TEST CONCERN CORRECTED,,A
Old 05-15-2011, 11:41 PM
Hate to be a bother but could you guys run one for me? 1FTSW21P15EA07063
Old 05-16-2011, 06:39 PM
You are awesome stnghlr. Been wanting that for a while.
Old 05-16-2011, 07:31 PM
xx2
