Strange noise part 2 - Ford Powerstroke Diesel Forum
post #1 of 11 Old 05-15-2011, 09:07 AM Thread Starter
I think I have now accurately made a video of the sound that my truck makes. I don't think this is a tea kettle noise, its loud when you shut the truck off then fades once the turbo stops spinning. I am going to buy an edge cs tonight and will be better able to give EOT and ECT temps to determine what the problem is..
Comments ?
Ronisonce is offline
post #2 of 11 Old 05-15-2011, 10:36 AM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
Sounds like a slight boost leak to me that causes a whistle as it leaks out under the lower pressure. Double check the boots and all the clamps.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 11 Old 05-15-2011, 11:02 AM
107stroker's Avatar
Quoted: 2 Post(s)
Do you have an egr block off in your up pipe? Mine did that but not as loud before i deleted tbhe egr completly.
107stroker is offline
post #4 of 11 Old 05-15-2011, 03:25 PM Thread Starter
No egr block at all.. At least not that I know of.. Just recently purchased the truck. I feel a bit more confident that its a turbo noise as opposed to coolant pressure. I honestly don't see how that sound could be coolant pressure at all.
post #5 of 11 Old 05-15-2011, 03:29 PM
NYC F-350's Avatar
Quoted: 49 Post(s)
Stick your head near the coolant degas bottle and give a listen. Knock on wood that that is not it.
Please
post #6 of 11 Old 05-15-2011, 07:40 PM
I agree - sounds more like a turbo bearing issue than the tea kettle noise. Can you use a hose like a stethoscope and put it on the turbo as the engine winds down?
Mark
06 F250CC SB FX4 Lariat;ARP studs;OEM gaskets; Banks exhaust;DynaTrac Ball joints;Coolant filter; High-Idle;RACCCV6000;JimmiJammers;Ravelco;SynchroMax trans case;Fumoto valves;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower270AXP;PowerInverter;Rancho7000's; BPD EGR cooler;One-piece HPOP fitting;BilletWaterPump;SCT w/ Matts SRL;ELC Ultra
bismic is offline
post #7 of 11 Old 05-16-2011, 06:28 AM Thread Starter
I will try that next.
post #8 of 11 Old 05-16-2011, 06:56 AM
Another thread to follow, lol
I hope this turns out well for you. Then I'll know what to look for on my truck. I'll be following closely.
Fishermedic is offline
post #9 of 11 Old 05-16-2011, 10:51 AM Thread Starter
Just purchased my Edge Insight CS with expandable egt sensor.. I'll update with how my temperatures look during the week.
post #10 of 11 Old 05-16-2011, 03:59 PM
Sounds like a dry bearing or bushing
StewBr is offline
