Re-gearing with STOCK size tires - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-15-2011, 06:05 AM Thread Starter
ponyexpress94's Avatar
Question Re-gearing with STOCK size tires
Hey guys,
I have been thinking about re-gearing my truck axles from 3.73 to 4.10 or 4.30 in order to get a better start from a stand still and climbing steep hills around my home when pulling heavy trailers (not overloading, just near Max GCW). I know this kinda goes against good practice right now with fuel prices rising but I would like to get better torque multiplication. I don't drive more than 70 mph on the highways anyway because my fuel economy tanks above 70, so the higher revs won't be too high for my liking.
So here is my question....If I were to regear my D60 and Sterling 10.5 to 4.10 or 4.30 gears, can I recalibrate the PCM to show the correct vehicle speed on the speedometer or do I need to run an SCT, EDGE, or BANKS tuner to do this? Is this something the dealership can help me with or am I on my own?
Thanks in advance.
Patrick
2003 F-350 CC LB XLT 4x4
Feb 2003 6.0 Liter Diesel and Torqshift 5 spd Auto
FS2500 Engine Oil and Transmission Bypass Filters
Dieselsite Coolant Filter
C-Betr Spot Mirrors
Ford AIC
Cobra 29 ST NW WX CB
Weatherguard 117 Toolbox
Weatherguard Weekender Ladder Racks
B & W Turnover Gooseneck
ponyexpress94 is offline
post #2 of 4 Old 05-15-2011, 06:41 AM
Ironmover's Avatar
Check out superlifts website. They have a controller box that hardwires between the speed sensor and the PCM. I use one on my truck and it has two positions so you can run different tire sizes at the flip of a switch. You can live calibrate the box with a jewelers screw driver and it's infinentely adjustable. They're about $200.
There may be other similar products but that's all that I'm familiar with.
Stock sucks
More torque pleeze
21st century participant of the 2nd amendment
Republican
Ironmover is offline
post #3 of 4 Old 05-15-2011, 06:51 AM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
Its defiantly against the grain, but maybe I can help ya. I have factory 4.30's in my truck, and your mileage will tank hard if you drop that low in gearing. Stock programing was around 11-13 in the city and 14-15.5 out on the interstates. Both of those values are empty, you will find that the 4.30 gears don't drop as much under a load as the higher ratios do. I'm getting a little better tuned, but I gather you're not looking to put a programmer in your truck. Also, I'm running 2000rpms at 60mph, and 2500rpms at 75mph. As for getting off the line, the 4.30's will get that truck moving. If you regear, the dealership should be able to correct your speedometer without any problems. Think long and hard about regearing, and it goes without saying keep the stock parts in the event you want to go back to it.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #4 of 4 Old 05-15-2011, 09:03 AM Thread Starter
Thanks, I will look into that. I did not realize there was a simple aftermarket solution.
That information is very helpful. You are correct I would like to avoid tuners. Believe me, I'm giving this alot of thought before I do it.
Patrick
C-Betr Spot Mirrors
Ford AIC
