Restore/ Restore Plus success stories?
I recently started having coolant puke out of the degas bottle. Replaced the cap, just in case but that didn't fix it. Been reading tons of posts on here, and realize most of the time when the truck pukes, it is due to the EGR cooler, which is due to the oil cooler. Since this just started recently, is there any chance a few good flushes with Restore/ Restore Plus will clear up the issue?
I see a lot of threads on how to do it, when to do it, etc. Most are to clean the system prior to and/or after an EGR replacement/delete, accompanied by the oil cooler replacement. Anyone actually do the flush and it cure the issue? I need to get an Edge Insight to be able to know the diff in EOT/ECT, that I know. Right now getting ready to hit the road for about 2500 miles round trip so I can't swing the edge, then have to do the coolers. Right now I am going to flush with the Restore/Plus, pray for the best, but expect the damage is already done. Just curious is anyone has actually been successful, or if the restore is always just in prep for cooler replacements. I did the Bars Leak 10 min flush, then the Peak 3-6 hour flush (hadn't done my research when I did these). Still kicks out the degas bottle on an extended full throttle run. Will Restore do any different, or should I go ahead and plan on the coolers... If I do the coolers, I am trying to decide between delete and bulletproof cooler. Only reason for the cooler is in case I have to sell in the future, easier to sell with legal equipment... Any other guidance? I am all ears. EDIT: Also, is ELC just ELC. Before doing a bunch of reading here I bought Auto Zone brand ELC, but considering returning it and getting some Zerex or something better. |
All ELC are not created equal. There is a specification on ELC...for that matter Ford Premium Gold is marketed as an ELC. The maintenance required to keep Premium Gold within specification is much higher than simply switching to an EC-1 rated coolant...that won't elminate the need for maintenance but ALL coolants with nitrite base for cavitation/corrosion protection deplete the nitrite over time; Ford Premium Gold STARTS with VERY low nitrite levels without supplemental additive.
Go EC-1 and save yourself a lot of trouble and frustration. Jonathan |
Do yourself a favor and right after you drain the coolent do a reverse flush on the oil cooler. I know some people don't think that it works but I tried it with a rust clogged cooler off a truck and did the junk ever come out. This will aid in the restore cleaning out the silicates from the oil cooler. will this get 100% of the rust out, no but it does help. The cover gasket cost around $7 at the dealer.
Thanks for the info guys, very much appreciate it. I will return the el cheapo auto zone elc and get some good stuff.
As for the oil cooler flush I am sitting in the truck 30 min into the first restore flush... I may do some research on the backflush and see if I can knock that out before going further. I think I remember seeing a thread on it. No idea where to start on that job. Familiar with wrenching plenty, just not much on this truck... Is that all you need is a cover gasket to accomplish it? Will hit the dealership in the am. |
the clear hose I'm using is 3/4"ODx5/8"ID and when you do this remove the lower rad hose from the rad and let it drain into a bucket. BTW on the restore flush for best flush possiable let the thermostat in and run the truck for 2 1/2 hrs and no more than three. I have the part number for the gasket I will add it to this post in a little.
Interesting...cause it was recommended in another thread about flushing the coolant system that the thermostat be removed when flushing and doing so will aid in circulating the coolant with the restore instead of waiting for the thermostat to open.
I can tell you from firsthand experience that to get the temperature up to "at least 185*" as recommeneded by the Fleetguard Restore bottle you will either need to leave the thermostat in or make a winter grill cover out of some trash bags and blankets to restrict air flow to the radiator to bring the coolant temp up.
The temp delta on my truck was 10* apart and running three Restore flushes and one Restore Plus flush did not change my post flush temp delta one degree. I did not back flush the oil cooler, partly because I didn't have a torx bit to get the cover off and partly because I didn't feel like I would be able to get decent access to the open port without removing the turbo and boost tube. To the OP...if your truck is already puking coolant be it full throttle bursts or cruising, I would seriously reconsider taking the truck on a 2500 mile trip, or if you do, you better at least spring for the Edge Insight. That's a serious gamble with a truck showing that symptom. |
Thanks again for the info guys, much appreciated. |
