camper charging question - Ford Powerstroke Diesel Forum
Old 05-09-2011, 05:59 PM
So the wife and I are going to be renting a camper in a couple of weeks and I am a little slow. I was wondering if the 7 pin connection on my 06 Powerstroke will also charget the batteries when plugged in or if I need to run wiring to accomplish this or what? Sorry for the newb question!
Old 05-09-2011, 06:40 PM
It should be ready to go. but will only be powered while the key is on.
Old 05-09-2011, 06:42 PM
WHat he said. The 7-pin is setup for charging so as long as the camper is made that way you're fine. I have an '09 Rockwood and it charges the battery when the truck is on.
Old 05-09-2011, 07:48 PM
If the truck is factory wired for trailer tow and has the appropriate relays and fuses installed in the distribution box you're good to go!
Old 05-10-2011, 04:12 AM
Thanks! I will check the fuses and relays!
Old 05-10-2011, 05:17 PM
exactly what they all said!
My 2004 charges my camper perfectly with the factory plug in the rear.
