Real Towing Temps
Well finally got out this weekend and took the 5th wheel for quick trip. We did 300 miles round trip. Elevation started at 5000ft and ended at 10k. Lets just say that lots of long pulls a mile+ up grade. The truck worked hard.
Numbers: 5th wheel weight about 10k or less Temps out side were 50 to 83 Max speed limit 75 Truck .. See sig Max temp I was pushing the motor hard 238 on EOT & ECT running 3100rpm. Average pulls were 220 on EOT and ECT running 2100rpm-2500rpm Best pull speed limit 55 kept with traffic 200 on EOT & ECT running 1800rpm Trans never went about 170 On level grade EOT and ECT 200 give or take a few running about 2100rpm. I think the truck performed very well but I concerned when we get to the hot part of summer. What do you think? |
Looks great to me.
Thanks...
Can anyone tell me what are the MAX TEMPS the 6.0 can handle? |
Here you go I can't take credit for this I think BISMIC posted this in another forum. Its attached
temp doc.txt |
I looked at the max numbers in the temp doc.txt and I would say according to it I was running it to hard?
What kind of numbers are you all getting when pulling up a long grade? |
Seems a little high but nothing extreme. Oil cooler probably a little clogged
I tow a 15K RV all the time and use the Max Energy Programer and the Temperatures never go over 214F. If the truck gets to 214 its a big long hill, I usualy let off on the accelerator at 205F and downdshift because any higher then 207F the fan realy robs the engine of available power. I usualy go up a long 6 to 8 deg hills on 4th gear high and can gain on speed without heating up at 55MPH.
I just did a long hill the other week and beat a Ram that was towing the same RV unit as mine. He was on my tail at the bottom and very small in my mirror when I crest the hill. My ECT never went over 205F. I guess the standard tranny is a big advantage as I can control the RPM and gears the way I like them. |
Engine RPM's are your friend and slow down a bit when pulling the grades. While it is important to have airflow across your radiator, your engine makes a ton more heat when you have a heavy foot. Here is a link to a thread I started and some temps from a couple of my trips pulling a 12k 5th wheel. LINK to thread
